electric water pump?
Old 03-02-2008, 08:00 PM
Sunadaime
Sunadaime's Avatar
Default electric water pump?
would the high flow meizer electric water pump upgrade be worth it?
http://www.rpmoutlet.com/newv8steel2.htm#3
Sunadaime is offline
Old 03-02-2008, 08:10 PM
tbirdscwd
tbirdscwd's Avatar
Default RE: electric water pump?
I would probly do it if my water pump went out. But electric water pumps have been successful upgrade for quite a few years now. They will certainly free up a few HP vs the stock pump which runs off the belt. I just wonder how long they will perform on a DD.
tbirdscwd is offline
Old 03-02-2008, 08:13 PM
Stone629
Stone629's Avatar
Excellent mod. It's been proven unlike alot of other popular mods. Mezeire pumpsare good for an honest 9-11rwhp.
Stone629 is offline
Old 03-02-2008, 08:26 PM
01snake
01snake's Avatar
i will be doing this soon
01snake is offline
Old 03-02-2008, 08:30 PM
Sunadaime
Sunadaime's Avatar
k well thanks
its getting put at the top of my forgotten list XD right after my cobra swap or get a stock cobra anyway
Old 03-02-2008, 08:36 PM
Xemeth
Xemeth's Avatar
Now what size belt would you need with an electric pump? And what if you have Steeda UDP's (just the crank and alternator, obviously)?
Xemeth is offline
Old 03-02-2008, 08:41 PM
josh.davis
josh.davis's Avatar
just bought mine this weekend from summit racing. I didn't install it yet, b/c for a d/d you need a 30amp relay with leads.
http://www.meziere.com/ps-419-389-wik346.aspx
josh.davis is offline
Old 03-02-2008, 09:02 PM
Stone629
Stone629's Avatar
ORIGINAL: Xemeth
They come with an inert pulley mounted to the electric pump, so you just use your stock belt. No re-routing or anything like that.
Stone629 is offline
Old 03-02-2008, 09:03 PM
tbirdscwd
tbirdscwd's Avatar
ORIGINAL: josh.davis
If you order from brendspeed it comes with all necessary wiring and relay. You can also order the wiring/relay kit seperately.
Old 03-02-2008, 09:40 PM
Xemeth
Xemeth's Avatar
ORIGINAL: Stone629
ORIGINAL: Xemeth
What about with UDPs? Can you use the UDP water pump pulley on the elec pump and use the belt from the UDP's?
Xemeth is offline
Quick Reply: electric water pump?
