Car hesitates when starting... ?
Hi i was wondering if any of you guys have gone thru this because my car barely started with this problem whenever i try starting my car doesnt matter when or after runing the car for a while it cranks alot before starting and like a month ago i would only need to crank it once for like 2 to 3 seconds and it would start at the first try and now i have to crank it for about 8 seconds and it doesnt start at the first time it starts after the second or third try i checkd my battery and it was good, any advise will be apreciated thanks...
RE: Car hesitates when starting... ?
That was the longest run on sentence. I fixed it for you! And so I could actually read it!:
Hi. I was wondering if any of you guys have gone thru this because my car barely started with this problem. Whenever i try starting my car, doesnt matter when or after runing the car for a while, it cranks alot before starting. Like a month ago i would only need to crank it once for like 2 to 3 seconds and it would start at the first try. Now i have to crank it for about 8 seconds and it doesnt start at the first time. It starts after the second or third try. I checkd my battery and it was good, any advise will be apreciated thanks...
Fuel pump?
Anyone else? lol I have no idea.
Fuel pump?
Was having probs with mine starting on first try intermittently.Was almost as if it wasn't getting fuel, or the timing was off. That had been going on for a while. Finally CEL came on. Read the code, showed bad camshaft positioning sensor. Searched the board and found out that a bad alternator would cause that. Had the alt tested and it came back with bad diode pattern. It would charge fine at higher rpms, but little to no charge at idle. Make sure they check w/ an ammeter. Going to change out the alt tommorrow. Hopefully will be the fix. Maybe not the same, but worth checking. Also, when you turn the key to on position, not starting, you should here a whine of the fuel pump. But, in my experiences, fuel pumps usually either work, or go out. No in betweens.
GM's have had issues with their fuel pumps. I guess there is a valve that sticks open, and the fuel bleeds out of the lines, so every time you go to start the car, it takes time to re-prime the line.
Depending ion the milage, I would check the fuel pump. Check fuelpressure running, and bleed off.
thanks...
well i kno that any fuel pump can go out at any given time, but i just replace mine about 6 months ago. I also replace my sparkplugs about 3k miles ago, andmycar has 106kmiles. Also now that you guys mention i should check my alternator wit a volltimeter....
thanks
thanks
DrunknRuckus
08-23-2015 10:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
