Oil catch can
RE: Oil catch can
yea i lose about a quart every oil change which is every 3k miles...when i put my plenum on ihad the pcv hose lying on the ground and there was a small puddle of oil when i went to put it back on...
RE: Oil catch can
ORIGINAL: lizzyfan
ORIGINAL: fyouceeku
I'm a troll!
ORIGINAL: 01GT4.6
not true
ORIGINAL: fyouceeku
not needed unless you are supercharged
I'm a troll!
RE: Oil catch can
Oil comes out of the drivers side valve cover on my car. It's got me confused. I was loosing oil so I run the passenger side to a little filter. I was still loosing oil so I took the drivers side loose from the power pipe right before the blower and there was oil in there. I run that one to a vent as well and it's still got oil coming out of the vent on the drivers side so I guess I need to put a catch can on that side. I probably loose a quart in between oil changes. It didn't do that until I put the heads and cams in.
