QA1 and header help for 2001 Bullitt
Old 03-07-2008, 09:22 PM
Bullitt2786
Bullitt2786's Avatar
Default QA1 and header help for 2001 Bullitt
Okay, so I need some help... I am putting a QA1 Pro-active front suspension and CAM longtube headers under my 2001 Bullitt. The k-member is okay (minus the problem with probablyhaving to add an extra hole to the motor mount bracket on the drivers side). I am just having issues with the headers rubbing on the passengers side framerail and the firewall on that side. I'm thinking getting the motor mounts mounted correctly will solve most of this problem. Never the less, anyone run into this problem?? Also, the sh*tty adjustable control arms are blowing my mind completely as far as mounting, alignment, etc. Any help on this subject will be MUCH appreciated!!! Or, if you have helpful pics lazrfst_steeda@yahoo.com or call me anytime at 615-904-4351. My name is Chris--Thanks in advance!!
Bullitt2786 is offline
Old 03-07-2008, 10:26 PM
oxfordgt
oxfordgt's Avatar
Default RE: QA1 and header help for 2001 Bullitt
Grind the bump off or the driverside motor mount and everything will line up fine. How far are you from Clarksville TN. If your close enough I might be able to help you out. I have longtubes and QA1 K.
oxfordgt is offline
Old 03-08-2008, 10:53 AM
Bullitt2786
Thank man but I think we have figured out the problem....The car has been wrecked before and I think the drivers side framerail is pushed over just enough it is hrowing everything out of whack. Now my big plans are shot [&o]. So if you see anybody needing all this stuff It's for sale. The struts and coilovers are brand new in the box. I'm ready to burn this damn car lol.
Old 03-08-2008, 11:04 AM
oxfordgt
oxfordgt's Avatar
You got any pics?
oxfordgt is offline
Old 03-08-2008, 12:27 PM
Bullitt2786
Pics of the stuff on the car or off?? It's in the shop on a rack right now. I won't be doing anything with it until monday morning. I guess I'm going to end up putting the stock manifolds and suspension back under it because I'm fed up wih it. LOL
GimpyHSHS
19
12-19-2023 01:12 PM
69MustangCoupe393cid
10-03-2015 10:33 AM
Sixer4Life
09-29-2015 07:03 PM
junior04
09-28-2015 10:53 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: QA1 and header help for 2001 Bullitt
