electric water pump
Old 03-09-2008, 11:12 AM
oxfordgt
oxfordgt's Avatar
Default RE: electric water pump
I paid $330 for mine and you don't need that relay. These pumps are good for 10,000 hours. They will out last you. They are perfect for a daily driver especially if you sit in traffic alot.
The only problem I have noticed is the damn thing works too good. When I come out of the bar at 3am and its 25 degrees the car never warms up enough by the time I get home and I just shiver.
oxfordgt is offline
Old 03-09-2008, 12:00 PM
Sxynerd
Sxynerd's Avatar
Go home earlier! Thats what us old people do. Oh wait I haven't been able to go to the bar since I got old... Or was that the other way around? Either way, I'm old.
I drove my stroked 383 carburated Nova from california to michigan 2400miles one way, "twice" with an electric WP and an aftermarket radiator. 10.5:1 compression 20mpg with a 700r4, stock 3.08's IN JULY. BTW thats through death valley.
I'm sure they are better than they ever used to be. I did this 4 years ago. And I know the current owner of the Car and it's still going strong. ( although it's a track car now) I drove my car everyday 18k miles a year. Id say that WP has about 50k on it by now. Case closed.
Sxynerd is offline
Old 03-09-2008, 12:57 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
I've never really looked these up. Do they come with any sensors to let you know the water pump's motor is one it's way out or not pumping as it should be?
96GT226410 is offline
Old 03-09-2008, 03:26 PM
califas_1987
califas_1987's Avatar
As I understood oxfords other post, its not as much about how much HP you gain with the eWP, but its more about improving your cooling system as a whole, and thus being able to run a more aggresive tune than you otherwise would be able to when your temps go higher. If I'm correct, he not only added the eWP but also did the coolant mod which improves water flow and circulation on your heads (water flows out the back vs. the front as stock).
Its more about the whole picture and what possibiliteis open up and what you can do than what just one single mod can do and what its direct improvement is.
Kinda like overclocking a cpu.
califas_1987 is offline
Old 03-09-2008, 04:04 PM
tbirdscwd
tbirdscwd's Avatar
That may be the case, but you will also see direct HP gains as well. The belt driven water pumps cost your engine some hp to run. This is called parasitic loss. Any engine riven pulleys cause some sort of loss in power because they take power to be run. When you remove this drag caused by the water pump pulley and replace it with an electric driven unit, you gain back the HP that it took to run it.
tbirdscwd is offline
Old 03-09-2008, 08:27 PM
califas_1987
ORIGINAL: tbirdscwd
Very true, but the reason I brought all that up is because several members were questioning wheather the $$ invested in the eWP was worth the direct HP gains. IMHO the direct HP gains by themselves really dont merit the investment, but once you start looking at it as a supporting mod for other areas of improvement PLUS the direct HP gains, I would say the investment is worth the money.
Oxford, why dont you chime in? How much more HP where you able to get out of your tune with the improved cooling system?
Old 03-09-2008, 10:31 PM
josh.davis
josh.davis's Avatar
I have the water pump sitting in my garage and hopefully it will put on bye this weekend.
buy it from brenspeed b/cthey sell it for like $330 with the relay kit. I bought mine from summit for $345 and it didn't come with the relay kit and they wanted forty buck for the relay kit. THANK GOD THEY PRICED MATCHED
josh.davis is offline
Old 03-09-2008, 11:53 PM
oxfordgt
oxfordgt's Avatar
I don't go to dynos (waste of money). But I am on my 3rd tune with 26* of timing and still no detonation. I'm gonna write another one tomorrow to see what I can get. I'm still waiting for my gauge pod so I can put in the wideband and finish my tuning but as it sits right now I am taking down 04 cobras without much effort (raced 2 so far).
oxfordgt is offline
Old 03-10-2008, 12:49 AM
avlon06
avlon06's Avatar
ORIGINAL: oxfordgt
just amazes me how much suspension mods really help, and he doesn't have very many power mods... my hat is off to you sir!
avlon06 is offline
Old 03-10-2008, 06:38 PM
tbirdscwd
tbirdscwd's Avatar
I got mine in the mail from brenspeed today. Was 337 including the relay kit from Meziere and free shipping! This thing looks pretty damn cool! Although, its not going on till I get my forged bottom end. No point in installing it now just to swap it in s few weeks to a new engine.
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: electric water pump
