Is my car ready for a supercharger?
Old 03-10-2008, 07:55 AM
SixEight
SixEight's Avatar
Default RE: Is my car ready for a supercharger?
I'm sure it's safe with a conservative tune, but it's definitely worth warning people that you need to be careful with a PI swap and a blower.
SixEight is offline
Old 03-10-2008, 09:21 AM
97stanger
97stanger's Avatar
ORIGINAL: nanaki
ORIGINAL: 97stanger
you're not going to be able to run much boost with that PI swap due to compression if you want that motor to last
tell that to lizzyfan. he ran like 9psi or something on his PI swapped GT just fine.
You call 9psi a lot of boost? The stock kit comes with 8psi....i was referring to 10+psi. Plus, if im not mistaken he ran just the 8psi pulley.
97stanger is offline
Old 03-10-2008, 09:41 AM
Chris98Gt
Chris98Gt's Avatar
Yea, you can boost a pi swapped gt, but not much. I'm running 8psi right now, but I won't up it untill I forge the internals with lower compression.
Chris98Gt is offline
Old 03-10-2008, 12:00 PM
nanaki
Retired MF Moderator
nanaki's Avatar
ORIGINAL: 97stanger
ORIGINAL: nanaki
ORIGINAL: 97stanger
when the majority of stock block stangs run 9-10psi max, yes, i call that a lot of boost. so 10+psi is a lot, but 9psi (1psi less than what you said) is not. got it!
even if he was running the stock 3.60 pulley, i'm pretty sure he had a powerpipe which gives at LEAST 1psi more.
nanaki is offline
Old 03-10-2008, 01:03 PM
Chubstang
Chubstang's Avatar
ORIGINAL: 2000GT4.6
ORIGINAL: stanggang1892
IF it was ME.... i wouldnt mess around with your current engine. If you can afford it and its what you like, i would go for the LS1, but i am a bit biased. But if the mustang is what you like, then stick with it! Get a forged motor and boost the snot out of it!
If only it didn't look like a retarded catfish and fall apart at 60K miles....
+100000, except my buddies 01 is falling apart and it has just under 30k on it.
Chubstang is offline
Old 03-10-2008, 01:04 PM
cody91mustanglx
cody91mustanglx's Avatar
first of all u need to sell ur 4.6 and buy a 5.0but your car is ready for a supercharger, dont go with a turbo unless its twin turbo
cody91mustanglx is offline
Old 03-10-2008, 10:15 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: 97stanger
ORIGINAL: nanaki
ORIGINAL: 97stanger
Anything over 9-10 PSI isn't going to work on a regular stock PI stang anyway... so either way you need to pull it apart and rebuild. At that point you can run dished piistions anyway... so who cares?
Its all in the tune.
2000GT4.6 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
UINZWAY
S197 Shelby Section
08-05-2015 10:34 PM
Quick Reply: Is my car ready for a supercharger?
