RPMs wont go down!!
Old 03-11-2008, 04:23 PM
stangman08
stangman08's Avatar
Default RPMs wont go down!!
on my 98 gt, when i rev it up it takes forever for the rpms to drop back down. iv noticed when im drivign down the road, my rpms are higher than normal then after a few seconds they drop back down.i have no clue wats wrong with it. please help!
stangman08 is offline
Old 03-11-2008, 04:33 PM
AmericanRicer87
AmericanRicer87's Avatar
Default RE: RPMs wont go down!!
Idle air controller might be gummed up, But i would run some injector cleaner through it and replace the fuel filter. the cumputer trys to cut the fuel back and it see's that when it does it too fast the car drops below set idle rpm and it learns it needs to do it slow. It's what mine did. and there are several post on here about this same thing.
AmericanRicer87 is offline
Old 03-11-2008, 04:41 PM
andysm
andysm's Avatar
2nd on the Idle air sensor. All of them need changed after about 50,000 miles. Also once it is running at idle, look at the tach and see if it is jumping a little bit, if so jerk that thing off and replace it for about $50 or $60 bucks.
andysm is offline
Old 03-11-2008, 06:57 PM
stangman08
stangman08's Avatar
iv already changed the fuel filter. so change the sensor or the idle control valve?
Old 03-11-2008, 11:01 PM
AmericanRicer87
They are the same piece. But yeah they go bad because of the egr valve putting carbon into the intake.
Old 03-11-2008, 11:18 PM
01snake
01snake's Avatar
LET OFF THE GAS
lol, just messin
01snake is offline
Old 03-12-2008, 12:46 AM
NinetySix GT
NinetySix GT's Avatar
https://mustangforums.com/m_2625353/tm.htm
DO IT SON, but your gonna lose your high idle during a cold start.
NinetySix GT is offline
Old 03-12-2008, 03:32 AM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
+1
http://s70.photobucket.com/albums/i8...t=CIMG0113.flv
99BlackPonyGT is offline
Old 03-12-2008, 02:55 PM
AmericanRicer87
You haven't messed with the idle screw have you? and make sure the iac is still plugged in ok. pull it off the car and if you see carbon gummed up inside it should be replaced.
Old 03-12-2008, 11:17 PM
NinetySix GT
I would spray it down with t/b or brake cleaner first and use a cotton swab to wipe it out before replacing it.
Quick Reply: RPMs wont go down!!
