LCA install
RE: LCA install
there isn't much to it. you don't really need a write up, just unbolt enough stuff until you can get them off, repeat in reverse order.
just the lowers you might be able to get away with just unbolting them and nothing else. I had to remove my catback to get the front bolts out, but i had a custom exhaust. The bolts should be 18mm.
RE: LCA install
easy. jack the rear up. remove lower shock bolts, axle side quad shock bolt and sway bar. then yank the spings out. if you cant figure it out from here pay someone to do it. good luck man.
RE: LCA install
thanks all, got em installed today.. also can anyone tell me whats up with my springs, i created another thread so here it is..
https://mustangforums.com/m_4776701/...tm.htm#4776979
09-10-2015 08:39 PM
