DIY turbo single turbo systems
Old 03-14-2008, 09:37 PM
samtoyo
samtoyo's Avatar
Default DIY turbo single turbo systems
Hey guys I have a 2000 4.6 2v and im going to put turbo on ive been to many tuning shops and i get differnt reponses all the time my question is that Im gonna run 42 pound injectors lightning mass and mafia and a 255 lph pump do i need a aftermarket fuel pressure regulator also what kmember should i use
samtoyo is offline
Old 03-14-2008, 10:58 PM
Emanpimpster
Emanpimpster's Avatar
Default RE: DIY turbo single turbo systems
i think alot of people use the QA1 k member for turbo setups idk about the fuel pressure regulator, i would imagine that you would want a high quality regulator though. Losing fuel pressure in boost would be terrible for your motor.
Emanpimpster is offline
Old 03-14-2008, 11:06 PM
samtoyo
samtoyo's Avatar
cool well its a non return style fuel system but if i were to go with one which one should i use ?
samtoyo is offline
Old 03-15-2008, 12:25 AM
tbirdscwd
tbirdscwd's Avatar
As far as I know, you won't need an aftermarket fuel regulator on the non-return style systems. As far as the K-member is concerened, there is really no way to say which one your better off using if your constructing a turbo kit yourself. Yor best bet is to get a K-member and fabricate around it.
tbirdscwd is offline
Old 03-15-2008, 01:40 AM
2000GT4.6
2000GT4.6's Avatar
There is no fuel pressure regulator, installing one would require completely replumbing
the entire fuel system.
Its not nessicarry for you to install one anyway, your current setup (42lb/hr, 255 pump) means your going to be limited to around 500 WHP or less, and the stock style fuel system will handle that just fine.
2000GT4.6 is offline
Old 03-15-2008, 01:51 AM
tbirdscwd
tbirdscwd's Avatar
ORIGINAL: 2000GT4.6
2000GT4.6, I heard somewherre that there was an internal regulator in the tank. Have you heard that? I know that you did a cobra tank swap, did you see anything that looked like a regulator during the swap?
Old 03-15-2008, 01:58 AM
2000GT4.6
2000GT4.6's Avatar
I don't have the cobra tank swap, but I did the SVT focus swap, and I did not see anything like this. Also, the fuel pressure changed a pretty good amount when going from the stocker to SVT pump, so I would say there is no regulator.
Old 03-15-2008, 11:41 AM
99mustanggt
99mustanggt's Avatar
There is an electronic regulator on the driver side fuel rail.
99mustanggt is offline
Old 03-15-2008, 03:52 PM
tbirdscwd
tbirdscwd's Avatar
Thats a pressure sensor.
Old 03-15-2008, 10:19 PM
samtoyo
samtoyo's Avatar
well my hp goal is only 425hp im making this a safe turbo setup 'cause this is my daily driver car I might upgrade to a 310 lph fuel pump later....at what hpdoes a lighting mass air peg ive heard all kinds of reponces on that too
samtoyo is offline
Quick Reply: DIY turbo single turbo systems
