Throttle cable with BBK 75mm T/B
Old 03-15-2008, 01:09 PM
jagsfan
jagsfan's Avatar
Default Throttle cable with BBK 75mm T/B
I completed my install of a 75mm T/B and C&L / RPM plenum last night. It wasn't to hard to install, but I am having a HECK of a time getting the throttle hooked up. The old T/B had a rubber cam on it where the bullet from the throttle cable could slide right into it. It will NOT fit on the BBK T/B no matter what I try and I am worried about damaging the cable.
Anyone else have this issue? I was able to start her and she runs fine, but I need to the throttle cable hooked up. Any help would be greatly appreciated.
Jag
jagsfan is offline
Old 03-15-2008, 05:24 PM
BlackMustang02GT
BlackMustang02GT's Avatar
Default RE: Throttle cable with BBK 75mm T/B
i had some trouble with min also but i dont have a bbk just now my pedal gets a little sticky when i give it a little gas..... but it should fit? however you undid your calble the first time, redo it up to put the cable back? i dont see how it wouldnt fit?
BlackMustang02GT is offline
Old 03-15-2008, 05:38 PM
whitestang97
whitestang97's Avatar
yea i had the same problem with my pp 75mm...i just kinda stuck the cable in there for now...you might be able to drill out that hole a lil bit on the throttle body...
whitestang97 is offline
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
UrS4
10-03-2015 06:23 AM
breaking
10-02-2015 01:27 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Throttle cable with BBK 75mm T/B
