Transmission Temp Gauge
Old 03-18-2008, 01:57 AM
02GT87
02GT87's Avatar
Default Transmission Temp Gauge
Looking into getting one, Anyone have a clue how to install these? Thanks
02GT87 is offline
Old 03-18-2008, 02:08 AM
undecided.steve
undecided.steve's Avatar
Default RE: Transmission Temp Gauge
ORIGINAL: 02GT87
+1
I'm getting one as well along with a tranny cooler and larger finned pan.
Any DIY articles on how to install these things?
undecided.steve is offline
Old 03-18-2008, 02:12 AM
02GT87
02GT87's Avatar
ive done searches but no luck the question stays open an no one answers it completely
02GT87 is offline
Old 03-18-2008, 07:43 AM
Churchkey
Churchkey's Avatar
I have installed several. Remove the trans pan & inspect the trans internals for a place in the pan to weld a bung in that will not interfer with servos etc. Also consider the external area for interference with exhaust or whatever. If you have a sender with pipe threads the bung will have to be welded all the way around to eliminate leaks. Its best to weld this type of bung on the outside of the pan. IF you have a sender with straight threads for a drain plug just drill the pan & tack the bung in on the inside. The washer on the sender will seal it properly.
Churchkey is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
b8checker
10-08-2015 12:55 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Transmission Temp Gauge
