cooling system pressure check
Old 03-19-2008, 09:30 PM
colergruver
colergruver's Avatar
Default cooling system pressure check
If you don't do a pressure check right will it start leaking coolant? I took my car to a mechanic and after they did a pressure check my car isleaking coolant. What are the procedures for the pressure check? Thanks.
colergruver is offline
Old 03-20-2008, 05:08 PM
colergruver
Default RE: cooling system pressure check
anyone?
Old 03-21-2008, 03:28 AM
FDNYBullitt
FDNYBullitt's Avatar
They just pressurize the cooling system and see if it holds steady, about 18lbs. If they over do it then it could cause a leak but usually it will be at a clamp or the heater quick connectors, good luck.
FDNYBullitt is offline
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: cooling system pressure check
