IRS upgrade????
IRS upgrade????
Does anyone else feel the whole rear end lighten upwhen you hit a little bump in the road. In a turn it's a little nerve racking and I'd like to fix it. Am I dreaming when I start to look into a conversion to IRS on a 98 Cobra?
RE: IRS upgrade????
i felt and heard my wheels hop. I changed my shocks and what a difference. see if your shocks are worn either by looking at them and see if theres oil on them if there is they re blown. Or you can push down and if it bounces more then once when you let off you need new shocks.
RE: IRS upgrade????
ORIGINAL: SnakeCarDriver
What you feel is suspension bind, our sn95 chassis's have an archaic design that binds fairly easily under any load. A properly setup SRA cost the same as a properly prepared IRS, however the IRS will outhandle the SRA in almost every instance. The one thing I can recommend is if your not gonna be buying the halfshafts, toelinks, etc, is to replace all the stock rubber bushings with delrin bushings. But I'd recommend getting everything done before installation.
RE: IRS upgrade????
i heard the IRS has even more wheel hop....
+1 IRS will out handle the SRA in a road coarse but not at the strip....
i think IRS is more for daily driving, but the spring rates are stiffer
RE: IRS upgrade????
ORIGINAL: blknismo180
Most people argue that termie owners mostly run SRA's and whatnot, thats due to the fact that they do not really thuroughly research their alternatives. A properly setup IRS cost less than a properly setup SRA.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
