Cobra Calipers? WTF.
Old 03-24-2008, 01:26 AM
koumiss45
koumiss45's Avatar
Default Cobra Calipers? WTF.
Ok so I got a set of PBR cobra calipers but they are throwing my mind in circles. I know on my stock GT calipers they have the pins that the outer half slides on, these have no pins except for a small pin with a e clip that holds the top to the mounting bracket. Am I missing something or is this how these work?
koumiss45 is offline
Old 03-24-2008, 10:27 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: Cobra Calipers? WTF.
Assuming your talking about the fronts the cobra calipers should slide directly onto the GT hardware after you install the cobra rotors.
2000GT4.6 is offline
Old 03-24-2008, 10:52 AM
cdrew217
cdrew217's Avatar
Yeah, they should fit no problem. I just did the swap this past weekend. They are a bit different in construction, but they bolt right up.
cdrew217 is offline
Old 03-24-2008, 11:56 AM
Stangatic
Stangatic's Avatar
I just did mine and everything was pretty simple.... except for the bleeding of the brakes. I ended up having to take mine to a professional shop to have the brakes bled.
[IMG]local://upfiles/88113/C71833B2972340E9BA88F0F04C1B759B.jpg[/IMG]
[IMG]local://upfiles/88113/731C13D5200F4DB0903E7CBDAD55C5AD.jpg[/IMG]
[IMG]local://upfiles/88113/6714F9E3FE22495087AFB9C68A711E3E.jpg[/IMG]
[IMG]local://upfiles/88113/9BE3BC875ADD45529EFF424ABDDC1A02.jpg[/IMG]
Stangatic is offline
Old 03-24-2008, 04:25 PM
koumiss45
koumiss45's Avatar
So you used your GT bracket with the cobra caliper? Mine don't look nearly alike.
11-10-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
Dan04COBRA
09-30-2015 11:46 AM
maestro1024
09-21-2015 02:40 PM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: Cobra Calipers? WTF.
