Hi flow CATS
Old 03-24-2008, 09:44 PM
dug98cobra
dug98cobra's Avatar
Default Hi flow CATS
Anyone have problem passing emissions in Dallas running Hi flow CATS? About to be running twin turbos, X-Pipe into Hi flow CATS, 3" all the way back. Hoping not to have any emissions problems.
dug98cobra is offline
Old 03-25-2008, 01:59 AM
98MustangGT46
98MustangGT46's Avatar
Default RE: Hi flow CATS
Im from Mass. And i passed with my setup. Its in my sig. Not sure how Dallas is though.
98MustangGT46 is offline
Old 03-25-2008, 05:27 AM
jmac72187
corner carver
jmac72187's Avatar
Do they still do the sniffer test on your car? Here in MA they stopped the sniffer test on OBDII vehicles.
jmac72187 is offline
Old 03-25-2008, 12:24 PM
98MustangGT46
^ Read your post wrong.
Old 03-25-2008, 12:42 PM
N3TD3V!L
N3TD3V!L's Avatar
ORIGINAL: jmac72187
Yes, they still do the sniffer test when you have the emission test done in Texas.
N3TD3V!L is offline
Old 03-25-2008, 03:44 PM
tbirdscwd
tbirdscwd's Avatar
ORIGINAL: N3TD3V!L
ORIGINAL: jmac72187
Good luck passing the sniff test with an aftermarket catted pipe. They don't clean up the exhaust nearly as much as the stock 4 cats. Thats why people often throw catalyst codes from their MILs even with catted mids.
If you really want to be safe for the inspection, just keep your stock pipe and swap it before the test.
tbirdscwd is offline
Old 03-26-2008, 06:02 PM
dug98cobra
dug98cobra's Avatar
Thanks for the info. The only problem is that the new system will be 3" all the way from the headers back. I guess I could rig up a bolt incollector style adapter to downsize to the 2.5" and then back up to the 3" on the other side???? Maybe???
ak98
02-18-2023 08:36 AM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
Quick Reply: Hi flow CATS
