Engine shaking and Maintenance light came on
Old 03-25-2008, 08:30 PM
mustangbeast
mustangbeast's Avatar
Default Engine shaking and Maintenance light came on
Well I washed my engine today and when I went to drive my 99 Mustang the engine shakes and the maintenance light came on. Anyone got any suggestions? I hope nothing blew
mustangbeast is offline
Old 03-25-2008, 09:07 PM
91smokedgt
91smokedgt's Avatar
Default RE: Engine shaking and Maintenance light came on
sounds like you have a misfire happening. something you will need to attend to asap. id say it was from washing your engine, i see it everyday. do you have a gt or v6?
91smokedgt is offline
rdmypny
rdmypny's Avatar
does the engine run funny like spit and spuddering?[/align][/align]
rdmypny is offline
Old 03-25-2008, 09:15 PM
mustangbeast
I have a Gt 4.6 engine.
Old 03-25-2008, 09:17 PM
mustangbeast
yea it sounds like it spitting and spuddering. It ran fine to the store and on the way back the light came on and I noticed the shaking
Old 03-25-2008, 09:25 PM
91smokedgt
91smokedgt's Avatar
yeah it sounds like a mis fire. id take to autozone or advanced they should be able to pull the code for you no charge. if it is a misfire check the plug first on the cylinder, then check your coil on plug.
Old 03-25-2008, 09:28 PM
mustangbeast
Should I just pop the hood and let it dry??
Or is something definatly have to get replaced?
Old 03-25-2008, 09:30 PM
rdmypny
rdmypny's Avatar
sounds like a vacume leak
rdmypny is offline
Old 03-25-2008, 09:31 PM
mustangbeast
It was all fine till I washed the engine...
Old 03-25-2008, 09:36 PM
91smokedgt
91smokedgt's Avatar
i doubt letting it dry will do anything, but you can try. if it is the plug def. get it replaced. you might want to check over your motor to make sure your didnt knock any sensors loose especially if you used pressure washer. you will want to get the code first if your light is on.
Quick Reply: Engine shaking and Maintenance light came on
