need advice!!!!!!
Old 03-25-2008, 09:02 PM
rdmypny
rdmypny's Avatar
Default need advice!!!!!!
i got a 98 GT and want to do the PI swap, what all do i need to do or get? will the fuel system and computer still work?[/align][/align]
rdmypny is offline
Old 03-25-2008, 09:10 PM
Chris98Gt
Chris98Gt's Avatar
Default RE: need advice!!!!!!
Fuel system and computerwill work, but I'd suggest getting it tuned afterwards for a few moreponies. Try andget a set of late 01-04 pi heads and all you'll need is a head change kit, a pi intake, and a pi coolant line that goes around the pi intake instead of under the npi intake. If you can get a npi aluminum coolant crossover plate with 2 temp sensor holes swap that one onto you new pi intake so you dont have to drill and tap a new hole. If you can only get a set of 99-mid 01 pi heads you will need new valve covers and a few larger timing case cover studs, and the chain guides will only be held by 2 bolts on the passenger head. (thats no big deal tho)
Chris98Gt is offline
Old 03-25-2008, 09:14 PM
rdmypny
rdmypny's Avatar
how much was your cams? and where did you get them? is it a naticable differance after the swap?[/align][/align]
rdmypny is offline
Old 03-25-2008, 09:19 PM
Chris98Gt
Chris98Gt's Avatar
I got my cams and valve springs from modularmustangracing before I knew about modularpowerhouse. I think it was around $900 shipped to me. I don't know how much a difference they made since I did everything at onceexcept the procharger,but after the swap I was out test driving it and I was on the limiter before I knew it. It definitly pulled up top much better. They also have a nice lope at an 800rpm idle.
Old 03-25-2008, 09:22 PM
rdmypny
rdmypny's Avatar
ok next question, what is the rev limiter set at on a stock 98 gt? whats the highest safest RPMon the stock bottom end?
rdmypny is offline
Old 03-25-2008, 09:25 PM
Chris98Gt
Chris98Gt's Avatar
Stock limiter is 6000 or6250 I think, Tim set my limiter on 6500 after he tuned it, I wouldn't turn it any higher than that since stock stuff won't make power that high and it won't hold up long.
Old 03-25-2008, 09:27 PM
rdmypny
rdmypny's Avatar
ok just wondering cause the intake i was looking at makes 23 more hp than stock at 6300 i got a SCT and i think i got the limiter set at like 5500 cause i wasn't sure and didn't wanna blow it up[/align]
rdmypny is offline
Old 03-25-2008, 09:29 PM
Chris98Gt
Chris98Gt's Avatar
A stock npi car isn't making any good power after that anyway so you weren't hurting yourself.
Old 03-25-2008, 09:31 PM
rdmypny
rdmypny's Avatar
ok i set it there cause thats about where i felt it quit pulling
rdmypny is offline
Omgitsa88Stang
10-05-2015 07:33 AM
Shadow7874
09-24-2015 09:06 PM
2k232
09-16-2015 10:28 AM
EASTIDEE123
09-15-2015 11:08 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: need advice!!!!!!
