Question about my mods and running lean
Old 03-28-2008, 11:23 AM
Nitti00GT
Nitti00GT's Avatar
Default Question about my mods and running lean
Ok with the mods I have now and the 75mm tb I just got, would I need to upgrade my injectors? I don't wanna get the car on the dyno just to find out that I can't get as much power as I would if I had bigger injectors.
Nitti00GT is offline
Old 03-28-2008, 11:38 AM
98SN95
98SN95's Avatar
Default RE: Question about my mods and running lean
what injectors do you have now?
98SN95 is offline
Old 04-01-2008, 11:41 AM
Nitti00GT
Nitti00GT's Avatar
Stock 19# injectors.
Old 04-01-2008, 05:48 PM
fobra570
fobra570's Avatar
i would say prolly not but if ur worried about it u could just pull the plugs and take a look at them
fobra570 is offline
Old 04-01-2008, 06:05 PM
oxfordgt
oxfordgt's Avatar
Your about 60hp away from needing to upgrade injectors. But if you get to the dyno and the tuner tells you need to upgrade tell him to eat **** and up the fuel pressure. 19# injectors at 85psi will function as 30lbs injectors. And don't worry the incectors handle 100psi. But you will not need to upgrade you fuel system with your mods.
oxfordgt is offline
Old 04-03-2008, 11:52 AM
Nitti00GT
Nitti00GT's Avatar
I heard something bout upping the fuel pressure causing the injectors to spray more but i didn't know if that was true or not. Thanks guys for the imput. It saves me bout 225 bucks.
Old 04-03-2008, 12:40 PM
SonicKbGt
SonicKbGt's Avatar
ORIGINAL: Nitti00GT
If you do plan on doing many more mods in the future doing the fuel system next before you run into trouble wouldn't be the worst idea
SonicKbGt is offline
Old 04-04-2008, 09:55 AM
Nitti00GT
Nitti00GT's Avatar
I was thinking about running a small shot of nitrous. I'm in school right now so it prolly won't be til I graduate.
Old 04-05-2008, 04:27 AM
bjh061487
bjh061487's Avatar
stock injectors can handle up to about 300 rwhp so you should be fine... but just keep an eye out cuz if you buy kenne bell they give you new fuel injectors for your car, so depending on what you do, the fuel injectors will be given to you
bjh061487 is offline
Old 04-06-2008, 05:14 PM
Nitti00GT
Nitti00GT's Avatar
ORIGINAL: bjh061487
I should be putting a tad over 300whp.
Quick Reply: Question about my mods and running lean
