PI Heads off of what car???
What cars come with PI heads, so I can just take them off of? And also what else is needed besides the complete head? Should I use the Cams that come with the PI heads? My search function dosent work for some reason.
[align=left] [/align]
RE: PI Heads off of what car???
well for the heads as far as i know you need the gasket..... ha dont know what else but there is a stiky that shows how to do a P.I intake manifold swap soyou can see what else are you going to need, IMO I think it is a money well spend for performance.
https://mustangforums.com/m_3833004/tm.htm
that is the link for the PI Intake Swap. as for the heads you are going to need gaskets and what not. ford sells a whole setup for changing the heads so you can go there. if i were you i would get the heads ported and polished before getting them put on so you don't have to change it later. just save up some more and do it right the first time instead of doing it partly right but then wanting it faster and dumping more money.
ORIGINAL: 40thGTKB
you need the heads/cams from a 99-04 GT. Those are considered "PI" heads
PI HEADS came only on 99 and early 2000 mustangs and on some saleens and roush's
And cams dont make heads "PI" Its the heads that are "PI" nothing else
Also u can use any cams for that head the only thing ull probably have to change is the valve springs
http://www.steeda.com/products/4.6L_...anging_kit.php
there is the link to a head changing kit from steeda. also as stated above, he is right BUT if you get PI heads you need to get a PI intake as well
ORIGINAL: saleen4162
no those are not PI HEADS
ORIGINAL: 40thGTKB
