White in oil?
Old 04-02-2008, 05:30 PM
99mustang38or46
99mustang38or46's Avatar
Default White in oil?
I just added some oil after work today it was alittle low. And when I took the oil cap off it had some white oily substace on the inside of the cap and looked as though it had started to run in a small stream down the tube the cap goes into. I am assuming just condensation but I wanted to ask you guys and make sure. just mostly in the cap. I haven't changed the oil since november but I have only put lik 1200 miles on it since then. So please just tell me it's condensation and by wiping it out all is well!
99mustang38or46 is offline
Old 04-02-2008, 05:38 PM
Adam03GT
Adam03GT's Avatar
Default RE: White in oil?
That exact thing happend to my car and i FREAKED. Called my buddy up (ford mechanic) and he said its perfectly normal buildup/condensation.
So ya your good.
Adam03GT is offline
Old 04-02-2008, 05:41 PM
Mustanggt9589
Mustanggt9589's Avatar
mine was doing the same thing still think its condensation but i will find out when i start driving her everyday again.
Mustanggt9589 is offline
Old 04-02-2008, 05:47 PM
Adam03GT
Adam03GT's Avatar
I drive mine everyday and change the oil just before 3k with a full synthetic. It just happens.
Adam03GT is offline
Old 04-02-2008, 07:21 PM
99mustang38or46
cool cool just wanted to make sure thanks
Old 04-04-2008, 10:19 PM
undecided.steve
undecided.steve's Avatar
ORIGINAL: 99mustang38or46
Normal on cars that are not driven a lot.
Not normal on cars that ARE driven a lot.
For the latter, check the PCV system.
undecided.steve is offline
Old 04-05-2008, 06:14 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
As "undecided" said, it is not normal on cars that are driven a lot--as in 10+ mile trips where the engine gets up to full operating temp and stays there for a while. [/align][/align]That's why short "around town" driving only is considered to be severe service, especially in colder climates.[/align]
cliffyk is offline
Old 04-05-2008, 10:16 AM
Jbauer
Jbauer's Avatar
Very normal. If you want it to go away, go have a little fun on the highway and clean the PCV valve
Jbauer is offline
Old 04-06-2008, 10:16 AM
jlg32281
jlg32281's Avatar
It might be normal if it's a small amount. The white oily stuff is a mixture of water and oil. It's never good to have water in your oil. If it is a very small amount, that's normal condensation, but this is also a sign of a blown head gasket. The easiest and best way to have peice of mind is to do a block test. Autozone rents the tool for free. You will have to buy a bottle of solution for the tool. It's about $7 and it's enough to do about 10 test. It's great to have on hand when buying a used car because it really sucks to buy a used car w/ a blown head gasket. (don't ask how I know). The test takes less than 2min and it's super easy. It test for exhaust gases in your coolant system, that's the sure fire way to know. Good luck.
jlg32281 is offline
Old 04-06-2008, 03:41 PM
Adam03GT
Adam03GT's Avatar
So mine gets driven every day but i work 2 miles away. Maybe thats why i get the stuff because i dont have a long trip.
In the summer it goes away though because of the frequent out of town car shows.
Adam03GT is offline
b8checker
10-08-2015 12:55 PM
breaking
10-02-2015 01:27 PM
14gt_Track
10-01-2015 02:47 PM
wraith777
09-28-2015 10:49 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: White in oil?
