performance package
performance package
i am purchasing a 2000 gt 5spd. i have been looking at performance upgrades and kinda had my eye on that slp 330hp performance kit. Is this advertised as crank hp or whp? What kind of power will i need to get into the low 13's or even high 12's?
RE: performance package
idk if it will give you that much..maybe 275-280
to get into the 12's you'll need
4.10's
shift kit
cams
heads
intake (wouldnt hurt)
Throttle Body
plenum
Headers
mid pipe
or a supercharger
4.10's
shift kit
cams
heads
Throttle Body
plenum
Headers
mid pipe
or a supercharger
ORIGINAL: boduke0220
4.10's
shift kit
cams
heads
Throttle Body
plenum
Headers
mid pipe
or a supercharger
4.10's
shift kit
cams
heads
Throttle Body
plenum
Headers
mid pipe
or a supercharger
can you put the link for this performance package?
and a shiftkit is for a auto... he is looking at a 5 speed so in this case its a short throw shifter... for the STS MGW ftw
http://www.mgwltd.com/mustang_shifter.shtml
that is a lot of money.... the reason its so much is because SLP headers are $800+... you can def get BBK LT and there mid pipe, for maybe 2 or 3 hp less and save yourself some money and then get some springs to keep your tires on the ground when you get all that done. also don't forget about install and header install can cut into the pocket pretty well sometimes. plus the tuner is by SLP, but quite frankly you want a Diablo or XCal. and that horsepower rating is def to the crank cuz they want to advertise the most hp they can without it being falsified so since crank hp is always more then wheel hp that is most likely where they are getting the numbers
