CYLINDER HEAD SWAP
Old 04-04-2008, 09:39 PM
stangy2004
stangy2004's Avatar
Default CYLINDER HEAD SWAP
i have to put a new pass side head in is it possible to leave my bbk header on and pull it up threw still attached to the cylinder
stangy2004 is offline
Old 04-04-2008, 09:43 PM
Ehmark
Ehmark's Avatar
Default RE: CYLINDER HEAD SWAP
Maybe you could drop the engine and raise the car like the chevy guys.
Ehmark is offline
Old 04-04-2008, 11:46 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
I doubt it. When I pulled my heads I was able to leave my stock manifolds on, but I doubt LT's will fit.
96GT226410 is offline
Old 04-05-2008, 12:15 AM
Zanador
Zanador's Avatar
Passenger side I don't see why not... Driver would be more of a problem due to the steering column in the way.
Just hope you are strong- that head and header prob weigh a decent amount, and you will need to contort it and move it around to get it out probably.
I would suggest having someone to give you a hand in leading it out without breaking something
Zanador is offline
Old 04-05-2008, 09:41 AM
98redstang
98redstang's Avatar
the passenger side maybe but itd be tight its worth a try tho your taking the heads off any way so why not do it all in one shot?
98redstang is offline
Old 04-05-2008, 10:12 AM
timeformiller44
timeformiller44's Avatar
yeah im sure u call pull it out as one assembly may be a bitch but it can be done im going to be installing heads and gong to try to attach the headers to head and slide them in..may work..may not work..i will find out
and a LT weighs less than a stock manifold hence...aluminum header...cast iron stock manifold
timeformiller44 is offline
Old 04-05-2008, 11:07 AM
98redstang
98redstang's Avatar
tell me how it wrks cause im gonna bedoing heads and headers also
Old 04-05-2008, 11:52 AM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
I actually believe in oxfords how to build an engine thread, he attached the passenger side header to the head before installing it.
One would think that if you could INSTALL with it attached, you could get it out.
72MachOne99GT is offline
Old 04-05-2008, 10:30 PM
99StangGTTN
99StangGTTN's Avatar
who makes aluminum headers timeformiller? lol
99StangGTTN is offline
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
b8checker
09-30-2015 07:11 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: CYLINDER HEAD SWAP
