PI SWAP QUESTION
Old 04-09-2008, 07:11 PM
mustanguser98
mustanguser98's Avatar
Default PI SWAP QUESTION
im trying to get some PI heads for my 98 i found some heads off a 01 crown vic would these be the right heads to use if i want the PI heads or are the PI heads only on the mustang? having a hard time finding anything off of a stang
mustanguser98 is offline
Old 04-09-2008, 10:18 PM
Sxynerd
Sxynerd's Avatar
Default RE: PI SWAP QUESTION
Make sure they are PI heads and not the NPIs. I believe that 01 was the first year of the PI on the Vics but I'm not certain.
EDIT: Also, 01 was a Romeo year for the mustangs, but make sure they are the same for the Vics. If they are Windsors than you'll need all new timing stuff too.
Sxynerd is offline
Old 04-09-2008, 11:04 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
ORIGINAL: sxynerd
+1, there are a few bolts on the timing cover that will need to be replaced if using Windsor heads. I think that there was 4 of them that were 8mm bolts and had to be changed to 10 mm bolts. I can't remember how many there were, but you can call Randy Stinchcomb at Liberty Ford and he can get everything you need...
By the way, I've done the PI swap and my advice is to get a whole PI motor. It's so much easier, you won't have that bump in compression (unless you want it ), and you can get a longblock with a lot less mileage that your origanal NPI. Ask sxynerd, he swapped out a full PI motor. Take it from somebody who has done the swap, just save up for a PI longblock.
96GT226410 is offline
Old 04-09-2008, 11:30 PM
Sxynerd
Sxynerd's Avatar
I only paid 800$ for my engine plus I got a whole bunch of crap I couldn't use. The whole swap costed me 950$ with buy a new clutch and oil and stuff.
Sxynerd is offline
04stangman
09-17-2015 01:45 PM
EASTIDEE123
09-14-2015 03:52 PM
jaiidutch
09-14-2015 10:29 AM
97SN95GT
09-13-2015 09:45 PM
Quick Reply: PI SWAP QUESTION
