HELP!! Tranny making ticking noise!
I got home today and decided to go wash my car. I got on it alittle and rippedfrom1st to 2nd to 3rd and then shifted to fourth normally.I got down the road like a mile and when I down shifted into third it sounded like a clunk noise came from the transmission and I felt it in the shifter. So I immediatley came back home and listen to it. And on my way backit did the same thing.While it idles, it makes a ticking noise then if i rev it up alittle the ticking becomes faster. you can feel a vibration in the shifter.Is my tranny done? Any help will be GREATLY appreciated.
RE: HELP!! Tranny making ticking noise!
ORIGINAL: BlackMUstang96GT
Your car = Broken...
Are you sure the ticking noise isn't coming from your engine?? If you're absolutely sure that it's your tranny, I don't think I've ever heard of that before, at least on a manual trans..
JT
JT
If the fork is broken, I don't hink that he would've been able to shift correctly to get it home after the first clunk... Although I do agree about the TOB..
Is there any additional slack or free play in the clutch pedal??
JT
JT
ORIGINAL: Derf00
Throwout bearing and fork. Push your clutch in, ticking go away?
ORIGINAL: GodAmGT00
JT
JT
