Mach audio and iPod
Mach audio and iPod
Hey all, I have a couple questions about my 02 GT coupe.
1) How do I tell which Mach Audio system I have in my car? The face of the stereo (which is a 6-disc changer) doesn't say it, and neither do the triangular window speakers on the corner of the doors. The triangular door speakers just have a gray label that reads "Mach Audio system". I do have two silver/grey amps under the rear speakers in the trunk.
2) If I do have the mach audio system, how can I hook up my ipod to work with it? I read about a special adapter that plugs into the CD changer port on the back of the stereo deck.
thanks
thanks
RE: Mach audio and iPod
dunno if you can tell, but are the amps in the back stock amps or are they aftermarket? if they are the stock amps then you have a Mach 1000 system if they are aftermarket you could either have a Mach 460 with amps added or the Mach 1000 with different amps
you probably have the mach 1000, because i have the 460 and it says mach 460 right on the speakers by the a-pillar...but if you want to hook up your ipod, go buy an adapter that you plug into the power outlet right in the center console and then plug the other end into your ipod- thats what i do- works great
Just go with a wired FM Direct Adapter. It's kind of a Hard wire FM transmitter. Regular FM transmitters sound like crap and always have interference. Courtesy of the FCC who made all manufacturers turn down the power. The Direct Adapters use an in-line antenna booster. They way I normally explain it to people is the FM T has to travel across the car to reach the Car Ant but the Direct Adapter is like laying the transmitting Ant and the Receiving Ant on top of each other. Less travel + better signal = Better sound.
One more thing, the Mach head units are VERY sensitive. Don't cut or splice any wires on the lead side of the Deck. It will check the Security light on very easily. Also most of 6disc changers have a sticker on top that says don't flip over if CD are inside. They also say SCRAP IF DROPPED. So be careful.
ORIGINAL: ryanc
thanks
thanks
Do you have FOUR amplifiers on the tray in the trunk?
Does the tray say "Mach 1000" on it?
Then you have a Mach 1000.
Based on what you wrote, it souncs like you have the Mach 460
As for the iPod hookup, if you are interested in good sound don't waste your money on ANY FM transmitter.
They all suck.
Some suck more than others.
Get this instead:
http://www.crutchfield.com/App/Produ...amp;i=581DFF10
ORIGINAL: undecided.steve
Do you have 2 subs in the trunk ?
They all suck.
Get this instead:
ORIGINAL: ryanc
thanks
thanks
They all suck.
Get this instead:
did you guy get factory tweeters with your system?? I DON'T!! I want the factory look of the tweeters toward the front of the side window next to the side mirror.. know what i mean?
well, i still can't figure out which system i have because i don't have the owner's manual. the deck nor any of the speakers say "460" or "1000" anywhere on them, just Mach Audio.
I am going to be replacing the head unit with a Panasonic unit that was in my old SRT-4. this unit has built-in iPod functionality and will be easy to integrate the Mach subs/amps with the headunit using this how-to:
http://www.stangnet.com/Tech-Article...Head-Unit.html
