Suspension?
Old 04-11-2008, 06:03 AM
bigpatsgt
bigpatsgt's Avatar
Default Suspension?
When buying a lowering kit with springs is that all you really need? Changing out springs will lower my car with out having to get new shocks or anything else?
bigpatsgt is offline
Old 04-11-2008, 07:03 AM
baino
baino's Avatar
Default RE: Suspension?
All you have to do is swap springs as long as you dont go extreme. If you just go with something like the a 1.75" drop all the way around, you would be fine. It will wear everything else a bit faster but not enough for much concern
baino is offline
Old 04-11-2008, 09:26 AM
bigpatsgt
bigpatsgt's Avatar
THANK YOU
Old 04-11-2008, 12:03 PM
indisposible_teens
indisposible_teens's Avatar
It is not going to be a very comfortable ride if you were to lower it 1.5" or more with the stock shock/strut combo.
indisposible_teens is offline
Old 04-11-2008, 01:38 PM
crash
BrandofPoop
crash's Avatar
might as well do em, shocks n struts at the same time as your springs...you may want caster camber plates too. Do it right the 1st time
crash is offline
Old 04-11-2008, 02:29 PM
bigpatsgt
bigpatsgt's Avatar
what about just shocks? Will be a big difference than stock shocks and lowering springs but still not as good as aftermarket shocks and struts?
Old 04-11-2008, 05:40 PM
Kdog2112
Kdog2112's Avatar
I would NOT just get springs. It will be a very rough ride on shocks and struts. What happens is when then lowering springs are put in the stock shocks and struts become compressed. Therefore, they are not truly providing a smooth ride. Itll be bumpy like all those kids who put suspension in the civic hatchbacks. Do truly lower the car and sustain a nice "tight" ride do the shocks/struts as well. Im a big fan of Bilstein/H&R setup myself. I had that setup on both of my BMW's and am doing the same install in the Mustang I just got. You will NOT be disappointed by doing it properly the first time as others have said previously in the post.
Kdog2112 is offline
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension?
