how do you disable pats
how can you disable pats, without having to go to the dealer, can you buy a programable hand held tuner, or can a car audio/alarm installed disable it, i need to disable it because my new- usedinstrument cluster will not let the car start, thanks.
RE: how do you disable pats
ORIGINAL: pipeguy
I could not stand when I used the tuner or the chip to disable PATS because the THEFT light would still flash even though the car was running. It was so irritating that I removed the bulb for the theft light.
Getting your PATS disabled is not always a good thing. With your PATS disabled, anyone with a non-coded duplicate key or possibly a screwdriver can start your car and drive off with it. There would be no starter kill at all.
Get your system reflashed. It's by far the best option (and most likely the cheapest). Then buy a chip or tuner.
how hard is it to switch the circuit boards, and what do they look like, another guy said he bought a bullit cluster and he swaped the white circuit boards and it all worked and kept the mileage like it was, thanks
ORIGINAL: pipeguy
On a scale of 1-10 I'd say it would be a 2-3.
My search in google was [ "simco gauges" +instructions ] My result was a jegs page that had the link to instructions which are in PDF format so you'll need a reader.
http://www.jegs.com/InstallationInst...3-2024-707.pdf
If you don't know how to use the search function for an internet search Use [ "......" ] quotes to search your main topic. Then to narrow your search use [ + ] or [ - ], For example above, I wanted to search for "simco gauges" and to narrow it I wanted any web page to insure it included the key word [ instruction ] so I used a [ + ] equaling [ +instruction ]. If I wanted to narrow by exclusion I could have used the [ - ]. i.e. [ "Simco Gauges" +instructions +mustang -chevrolet ]
mdvaldosta
06-12-2004 11:32 PM
