Spark Advance
Old 04-12-2008, 10:21 PM
Hatcher514
Hatcher514's Avatar
Default Spark Advance
Need help. My car is idling weird as if its misfiring. no codes coming up. hooked up my tuner and datalogged the car. Everything is fine except for the spark advanced. At idle the spark advanced is moving all over the scale from 20 to 45 in very speratic sequence. When the car seems to come back alive the spark stays at 20.
Hatcher514 is offline
Old 04-12-2008, 11:02 PM
sfi
sfi's Avatar
Default RE: Spark Advance
Whens the last time you changed your spark plugs as well as your o2 sensors. SOunds like your ecu is trying to compensate
sfi is offline
Old 04-12-2008, 11:21 PM
Hatcher514
Hatcher514's Avatar
O2 are new and the plugs have less then 3000 miles on them.
Old 04-13-2008, 12:57 AM
Hatcher514
Hatcher514's Avatar
CAN ANYBODY HELP?
Old 04-13-2008, 03:32 AM
2000AZ5.0GT
2000AZ5.0GT's Avatar
It's your Coil on plugs, Take each one out and check the Ohms, and make sure they are all consistant. I'm almost exactly sure that's whats going on, but I could be wrong
2000AZ5.0GT is offline
Old 04-13-2008, 07:10 PM
Hatcher514
Hatcher514's Avatar
I bought a meter and checked my coils there all consistant!
Old 04-14-2008, 01:18 AM
Hatcher514
Hatcher514's Avatar
No one has a clue? Could it be the Crank position sensor?
Old 04-14-2008, 10:40 AM
undecided.steve
undecided.steve's Avatar
ORIGINAL: Hatcher514
It can be the CPS or believe it or not the alternator which is known to cause problems with the CPS.
Is it throwing any codes?
undecided.steve is offline
Old 04-14-2008, 09:01 PM
Hatcher514
Hatcher514's Avatar
no, its clean of codes!
Old 04-14-2008, 09:25 PM
meechuacon
meechuacon's Avatar
Try swapping your COP's. I've been having problems with mine, especially when it's wet out.[&:] I even bought a brand new set of Granatelli's 2 weeks ago, and one went bad already, so I bought some ACCEL's this time. Water gets into my #4 spark plug hole and gets that coil damp or something and screws it up. RTV this time!!!!
meechuacon is offline
Quick Reply: Spark Advance
