air conditioning question
i was wondering if any one else has had this problem before, i turn my ac on and it blows out regular outside air it feels like, and than i turn on the heater and its the same air, i was wondering what could be the problem
RE: air conditioning question
ORIGINAL: timeformiller44
need to get a recharge then have them put dye in the system and when it/ if it...dies agian see if they can find the leak in the system
first of all when you say you put on the heat and it feals like the same air, is your heat working if not that could mean there is a problem with the vents switching. Also real quick check, see if the ac clutch on the compressor is cycling when ac is on. If not probably needs a charge. If it is you might need more than a charge. hope this helps.
