Not sure what kind mine is as I got it off ebay, but it leaked coolant into the rear pass. side cylinder, didnt know about it, and when to start it up after sitting for a few days, snapped the connecting rod right in half since the cylinder could not compress the coolant. My block also has a crack in it tho, so who knows. Easiest way to check is remove the plugs, and rotate the engine by hand with a socket on the crank pulley, look in the cylinders with a flashlight and if theres coolant you'll be able to tell.
if done right it shouldn't i had mine replaced on my car and i didn't have any problems with it afterwards. it's better just to switch to PI intake instead of paying $200+ for dorman replacement.
