need tips for traction
Old 04-14-2008, 10:39 PM
handyandy
handyandy's Avatar
Default need tips for traction
I find that when I accelerate quickly I loose a lot of traction and my rear starts slipping around. I know that with any gears if you just stomp on it it will be hard to get traction, but I feel like even when I don't even completely stomp on it its still hard for me. When I get up to around 3000 rpm its instant break loose in 1st and 2nd gear unless I get off the gas for a sec, but if I get on it again it'll do the same thing. I don't even want to go to the track because my times will suck, any tips on controlling this (besides getting drag radials/slicks)? Looking for tips on how to get some good traction with street tires.
handyandy is offline
Old 04-14-2008, 10:46 PM
97stanger
97stanger's Avatar
Default RE: need tips for traction
heres what i did and it helped drastically, and this is with a 400hp car
full length subframes
adjustable shocks/struts
adjustable upper control arms
welded torque boxes
aluminum lower control arms
and the main thing that will help the most is some nice radials (BFG or M/T)
97stanger is offline
Old 04-14-2008, 10:47 PM
01GT4.6
01GT4.6's Avatar
I know you said no drag radials or slicks, but a better tire is your best bet, unless you plan on doing a lot of suspension work.
01GT4.6 is offline
Old 04-14-2008, 11:07 PM
SINISTER
SINISTER's Avatar
ORIGINAL: 01GT4.6
Tires all the way, man. You don't have anything making your car too crazy, so a good set of tires should work. I have 4.30's and with my BFG drag radials I was able to hook great. I have the BFG g-Force T/A KDW II's now and they seem pretty good. No where near as good as the drag radials, but at least they should last much longer.
SINISTER is offline
Old 04-14-2008, 11:10 PM
97stanger
97stanger's Avatar
I thought the KDW IIs were a drag radial? what is bfg's radial?
Old 04-14-2008, 11:16 PM
SINISTER
SINISTER's Avatar
This is their drag radial: http://www.discounttiredirect.com/di...d=18&ar=35
This is the one I have now, the KDW II:
http://www.tirerack.com/tires/tires....es&place=2
The drag radial was great, but not for a daily driver. Wet weather traction was bad, and I only got 4k miles out of them (pushed it to 7k, but the steel belt was showing when I finally changed them). So far, the KDW II's seem good, but I have not been to the track with them. They definitely do not grab as good as the drag radials though, as now I chirp 4th gear any time I get on it.
SINISTER is offline
Old 04-15-2008, 08:43 AM
97stanger
97stanger's Avatar
got ya! thanks for clearing up the confusion...let us know what kind of 60's you can pull with the KDWIIs!
Old 04-15-2008, 04:34 PM
handyandy
handyandy's Avatar
Thanks guys, not enough money for suspension work right now. It looks like I should go with a better tire. I'm running 3 Kumho Ecsta ASX, and one STP on the front right (because I had a blow out and didn't want to wait for the tire place to order more ASX.) Think I should invest in some BFG's KDW II all around? Do these last pretty long? These are a more expensive tire correct?
Old 04-15-2008, 04:48 PM
97stanger
97stanger's Avatar
ive heard that the BFG's dont last too long in general, radial or not. If going with a street tire, i would highly recommend the Kumho Ecsta MX's. I run them now on a 400hp car and they are not terribly bad
stang4.6
stang4.6's Avatar
best streettire i herd are the nitto 555 extreme they got the traction the life and they street tires you should check them out...here the link http://www.nittotire.com/#index%2Etire%2Ent555
stang4.6 is offline
FivePointToTheOh
03-09-2020 10:26 PM
ChampInSD
10-02-2015 04:55 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
09-10-2015 08:39 PM
Quick Reply: need tips for traction
