maf question
Old 04-15-2008, 12:00 AM
medrick
medrick's Avatar
Default maf question
alright so i'm looking into a bigger maf sensor. is going too big bad? does it matter if you have a stock tb and plenum or the 75mm ones? i've heard a lot of people use the 90mm ones off lightnings. do i need just the sensor or the sensor and the black housing? also is the plug the same for the stock mustang sensor and lightning? i know thats a lot of questions but i don't want to screw anything up.
thanks
medrick is offline
Old 04-15-2008, 11:25 AM
josh.davis
josh.davis's Avatar
Default RE: maf question
i don't think you need to change your mass air flow untill your supercharged our have seriosly sick N/A car.
josh.davis is offline
Old 04-15-2008, 11:31 AM
tbirdscwd
tbirdscwd's Avatar
Leave it alone until you are, like said above, over 8psi on a blower setup or a nasty N/A setup. And by nasty N/A, I don't mean bolt-ons.
tbirdscwd is offline
Old 04-15-2008, 11:37 AM
my5thstang
my5thstang's Avatar
theres no need like they said, i just changed mine when i put on the S/C
my5thstang is offline
Old 04-15-2008, 11:51 AM
medrick
medrick's Avatar
alright i'll leave it alone then. what about the tb and plenum though? thye would be good to put on wouldn't they?
medrick is offline
Old 04-15-2008, 11:54 AM
tbirdscwd
tbirdscwd's Avatar
Unless you find a really good deal on a combo, then I'd just go with a 75mm throttle body.
my5thstang
my5thstang's Avatar
it will give you alittle throttle response quicker feels is all.
Old 04-15-2008, 11:56 AM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
You can change the MAF but it won't do ANYTHING for you performance wise. If you did then your car would run SRSLY lean. Your MAF would "think" there is less air coming in because the the opening would be bigger and have less "mass" then you would have to get it retuned for no reason.
35thAnni99GT is offline
Old 04-15-2008, 11:57 AM
bjh061487
bjh061487's Avatar
i would go with a combo from brenspeed... you can get the 75mm t/b and plenium from BBK for like 320 something... on brenspeed's website they actually have a 78mm t/b plenium in one and is cheaper then a t/b plenium combo
bjh061487 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
UrS4
09-30-2015 10:13 AM
Drastang
09-30-2015 03:48 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: maf question
