gear question
Old 04-16-2008, 04:43 PM
sb04gt
sb04gt's Avatar
Default gear question
I was told the day that the frpp gears do not have to be measured and shimmed. I want to order my 4.10s and of course if I don't have to shim them that would be great becuase I don't have all the dial indicators and stuff that I need, but I can borrow them from a buddy if need be.
sb04gt is offline
Old 04-16-2008, 05:32 PM
98redstang
98redstang's Avatar
Default RE: gear question
i dont kno about tht i hav 4.10's tht im waiting to install and im pretty sure u need the shims or else you get a terrible gear whine. I would check it out more b4 u just throw thm in.
98redstang is offline
Old 04-16-2008, 06:51 PM
02TorchRedGT
02TorchRedGT's Avatar
It will more than likely need adjusting...i would'nt chance it...too much work to redo.
02TorchRedGT is offline
Old 04-16-2008, 07:04 PM
bt1288
bt1288's Avatar
Someone gave you the wrong info.
bt1288 is offline
Old 04-16-2008, 07:56 PM
MineralGrey
MineralGrey's Avatar
definatley needs to be measured and shimmed!
MineralGrey is offline
Old 04-16-2008, 07:57 PM
SINISTER
SINISTER's Avatar
Whoever told you that is an idiot. All gears need to be measured and shimmed to get a proper installation. You should never listen to anything that person has to say about cars.
SINISTER is offline
Old 04-16-2008, 09:35 PM
mestit3
mestit3's Avatar
+1
mestit3 is offline
Old 04-17-2008, 04:20 PM
sb04gt
sb04gt's Avatar
Thats what I kind of figured. I can get a hold of the dial indictors and stuff to check backlash and pinion depth and stuff. I work with dial indicators everyday so doing it isn't a problem. Kind of new to the whole mustang thing so I didn't know if ford had come out with some gears to just drop right in, but then again that would not make any sense becuase every thing such as the gears and rear end have different tolerances that other gears and rear ends. Thanks for the feed back guys.
sb04gt is offline
Old 04-17-2008, 06:28 PM
SINISTER
SINISTER's Avatar
No problem, bud. Here is a link that is very helpful. Enabled me to do my own gears and they came out perfect.
http://www.superstallions.com/tech/d...ars/gears.html
SINISTER is offline
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
Mustangmalo
09-06-2015 05:22 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: gear question
