e85 gas ????
Old 04-19-2008, 12:25 PM
Blackvenom01
Blackvenom01's Avatar
Default e85 gas ????
Ok so i got a gas station round where i live and it sells e85 gas...i have been told and seen a few places that it is pretty much the equivalent of 115 race fuel but is bout 30cents cheaper then regular gas right now...Does anyone know if u can tune ur mustang to use this gas i got the sct x cal 3 im not sure if my tuner can do that....any info would be helpful..thanks!!
Blackvenom01 is offline
Old 04-19-2008, 12:52 PM
kecclest
kecclest's Avatar
Default RE: e85 gas ????
You will need bigger injectors and high flow fuel pump. E85 can make alot of power, but it is less efficient so you have to burn more to get the same results as gas. But to answer your question, yes you can tune your mustang to burn E85...but I would suggest getting it tuned on a dyno.
kecclest is offline
Old 04-19-2008, 01:14 PM
ponysnake99
ponysnake99's Avatar
Ethanol has a similar consistancy to alcohol, hence its high octane yet lower power yield per combustion compared to gasoline (as kecclest said). The seals in your fuel system and some metal parts will not hold up to ethanols chemical make up. and technically because of the power loss per unit compared to gasoline, a tune would do nothing and you would lose power, you would need to raise the compression of the engine to achieve the same results.
ponysnake99 is offline
Old 04-19-2008, 01:32 PM
Blackvenom01
so then it would pretty much be a waiste of time and money ir ur guys opinion
Old 04-19-2008, 02:02 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
ORIGINAL: ponysnake99
[/align][/align]Alcohol is abroadclassification of certain organic compounds.Ethanol is primary alcohol, 200 proof grain alcohol,as is methanol (wood alcohol). The isopropyl alcohol found in your medicine cabinet is a secondary alcohol, there are also tertiary alcohols.[/align][/align]You are 110% correct as to it's benefits and effects as an engine fuel. Fundamentally it's crap, and (leaving aside the fact that there is no way we could produce the quantity needed without starving off 1/2 the world) if it was any good as a general automotive fuel we would have been running it by now...[/align][/align]
cliffyk is offline
Old 04-19-2008, 04:02 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
ORIGINAL: cliffyk
+1. I'm a Chrysler/Jeep tech and we make a lot of cars that use E85. It's cheaper than regular, sure. But you get a lot crappier gas mileage and power.
96GT226410 is offline
Old 04-19-2008, 08:08 PM
Blackvenom01
thanks guys thats exactly wut i needed and wanted to kno
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Quick Reply: e85 gas ????
