engine removal
Old 04-26-2008, 10:09 AM
ponysnake99
ponysnake99's Avatar
Default RE: engine removal
Thats your ABS unit, and its easier to squeeze around that then try not to mess your radiator up. Afew bolts/electrical connector gets the fan and 2 bolts gets the radiator, half hour max.
ponysnake99 is offline
vinson581
vinson581's Avatar
i ddi an engine swap and didnt touch the radiator, i pulled the engine and tranny as a combo....just remember to remove your shifter and everything will clear perfectly fine
vinson581 is offline
Old 04-26-2008, 12:55 PM
pete1665
pete1665's Avatar
ORIGINAL: vinson581
sounds good. where did you attach the hoist to the engine?
pete1665 is offline
Old 04-26-2008, 02:55 PM
Mark99GT
Mark99GT's Avatar
I pulled my engine/trans with the radiator and hood still in place. It can be done, just go easy with it.
Mark99GT is offline
Old 04-26-2008, 05:32 PM
BlackMage
BlackMage's Avatar
ive pulled the motor with the trans on and radiator in and didnt have any problems clearin it, just take the hood off and have an extra body there to help steer everything
BlackMage is offline
Old 04-26-2008, 09:55 PM
jagsfan
jagsfan's Avatar
Guys:
I will be doing the same thing to do my PI Head and Intake swap and possible headers. Where is the best place to rent the equipment I need, i.e. cherry picker, engine stand.
Also what is involed in removing the engine. Is it hard to release to from the Tranny?
Thanks,
Jag
jagsfan is offline
Old 04-26-2008, 10:20 PM
NeedStangSpeed
NeedStangSpeed's Avatar
ORIGINAL: jagsfan
Guys:
Thanks,
Jag
As far as the equipment it's just as good to buy it, usually can get a desent deal on it somewhere even if it's online. Seperating the tranny from engine is easy depending on how you choose to do it. If it's in the car, it's harder of course, out a lot easier.
NeedStangSpeed is offline
Old 04-26-2008, 10:47 PM
Ehmark
Ehmark's Avatar
cherry picker/lift is only $150 and you will never need a new one the engine stand is even cheaper.
Ehmark is offline
Granatelli Sales
01-20-2020 12:34 AM
MusicCity615
09-27-2015 12:53 AM
spamedic
09-09-2015 12:15 AM
Gary Ugarek
09-05-2015 09:03 PM
Quick Reply: engine removal
