engine removal
Old 04-24-2008, 11:46 PM
pete1665
pete1665's Avatar
Default engine removal
Haynes manual says to remove the radiator before lifting the engine out. Is this really necessary for clearance?? Also... it sounds like its easier to pull motor/tranny as one??
pete1665 is offline
Old 04-24-2008, 11:52 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
Default RE: engine removal
If you remove the hood then removing the radiator won't be necessary. And if you're removing the trans as well, then take the engine and trans out as one. If you're not doing anything with the trans then just leave it in.
96GT226410 is offline
Old 04-25-2008, 12:20 AM
pete1665
pete1665's Avatar
nah im not touching the trans except for a new throwout bearing. If i leave the trans in, will i be able to slide the engine forward enough off of the input shaft of the trans and still clear the radiator??
pete1665 is offline
Old 04-25-2008, 02:05 AM
Ehmark
Ehmark's Avatar
Take out the radiator it doesnt take much to destroy it. I had to replace my radiator because I tried to save 15 minutes.
Ehmark is offline
Old 04-25-2008, 02:39 AM
Chupacabra
Chupacabra's Avatar
I agree w/Ehmark, one swing of that engine destroys the radiator.
Chupacabra is offline
Old 04-25-2008, 08:28 AM
pete1665
pete1665's Avatar
will do. thanks guys!
pete1665 is offline
Old 04-25-2008, 08:35 AM
1sloblckgt
1sloblckgt's Avatar
I would say remove the radiator as well... If youre taking out the motor, removing the radiator isnt anything but a walk through the park.
1sloblckgt is offline
Old 04-25-2008, 08:44 AM
pete1665
pete1665's Avatar
i thought i remember reading about a heavy duty throwout bearing that everybody said to use, but i cant find the thread... anybody know what that would have been?
pete1665 is offline
Old 04-25-2008, 09:13 AM
NeedStangSpeed
NeedStangSpeed's Avatar
In the time it will take you to get to the bolts holding the tranny on the motor, it will be much easier to pull it out as 1. Every time I pull mine, I pull everything. One thing I do is this, take drive shaft off at diff, zip tie it(or what ever it takes so it doesn't come out of tranny) so you don't make a mess with all the fluid. +1 on removing the radiator, it's simple to pull and a lot less frustating then having to replace it.
NeedStangSpeed is offline
Old 04-26-2008, 09:28 AM
pete1665
pete1665's Avatar
So i've gotten to the point where i'm about to remove the radiator, but i'm not sure that it would be worth it, because it looks like the brake proportioner(i think thats what it is) would still be in the way. See pic below.I really dont want to remove that, but is there something that i'm missing here?
[img=http://www.imagefire.net/thumb/c9110b72749e.jpg]
[IMG]local://upfiles/9009/96814C4C34514B44AE3B0A44EBC2016F.jpg[/IMG]
pete1665 is offline
Quick Reply: engine removal
