Throttle Body install on 03 Mach 1
I checked around on here and I cant find this information out. Does anyone know how to install a Accufab throttle body on a 03 Mach 1? I'm haveing trouble with this and it should be and easy install.
RE: Throttle Body install on 03 Mach 1
I also have a question I just recieved my plenum and throttle body in the mail today, it was used, there is a rip in the gasket, do I need to buy a new gasket for that, or as long as the whole gasket is there is it fine?
mach 1 aftermarket throttle bodies suck. They require a large amount of time and you have to mess with them a lot to get working correctly.
http://www.mach1registry.org/forums/...ad.php?t=35470
http://www.mach1registry.org/forums/...hlight=accufab
i see lots of people just giving up and selling it. good luck
OK, I installed the TB, IAC restrictor plate and K&N CAI. Now my mach has the damn check engine light on. I already pulled the neg on the batt so it can restart my ECU. That workded for awhile. I drove it for like 30min and turned car off to get gas. Turned it back on and there was the check engin light on. I think because of the IAC plate, I'm restricting too much air.
