Running lean cuz of an O2 sensor?
Old 05-14-2008, 09:30 PM
steedondubs
steedondubs's Avatar
Default Running lean cuz of an O2 sensor?
I been noticing my car was running like shi* when id stab the gas... So I tookit in for a scheduled oil change and the guy told me my front O2 sensor was unplugged & had just been dragging the ground... Its greenconnected to a white wire. The guy that replaced my starter didnt plug it back in whenever he did what he did... So I wanted to know if that sensor bein unplugged would cause the car to throw the run lean code, throw off the A/F,and drive like crap whenI stab the gas??????
steedondubs is offline
Old 05-14-2008, 09:38 PM
jrherald420
jrherald420's Avatar
Default RE: Running lean cuz of an O2 sensor?
yes
jrherald420 is offline
Old 05-14-2008, 09:39 PM
Sxynerd
Sxynerd's Avatar
Simply yes it will throw the code but the Heated 02's only tell the eec that the computer is lean or rich (on or off / 0,1) If you are getting a lean bank or cylener I'd try changing out your plugs too.
Sxynerd is offline
Old 05-14-2008, 09:41 PM
steedondubs
ok. Is that a yes to all 3 questions?
Old 05-14-2008, 09:43 PM
jrherald420
yes,yes and yes
Sxynerd
Sxynerd's Avatar
yes x3
Sxynerd is offline
Old 05-14-2008, 09:47 PM
steedondubs
How'd i know yall would answer with 3 yes's. Thanks fellas... That shouldn't be too much to replace should it?
Old 05-14-2008, 10:09 PM
ZW99GT
ZW99GT's Avatar
It's about $50 from Autozone, and you can install it yourself with a wrench in your driveway.
ZW99GT is offline
Old 05-14-2008, 10:15 PM
Brute03
Brute03's Avatar
but how are you getting a lean code if the sensor is unplugged? i'd expect malfunction code [&:]
Brute03 is offline
Old 05-14-2008, 11:06 PM
Sxynerd
Sxynerd's Avatar
ORIGINAL: ZW99GT
7/8's/22mm and I changed mine this morning. It took me longer to find my jack handle than it did to change my 02.
Sxynerd is offline
Quick Reply: Running lean cuz of an O2 sensor?
