Clutch Adjustment Issue: Not releasing off the pressure plate far enough
Ok, So my clutch is adjusted perfect. When I pull the fork back, the T/O Bearing is about 3/8" away from the splines on the pressure plate. But it doesnt stay that way. When driving the car it doesnt push off the splinesfar enough to stop the T/O bearing from spinning. Its almost as if I need some type ofreturn spring on it. If I tighten it up then it stays against the pressure plate but if I loosen it then theres slack in the cable and it just spins. Anyone run into this issue? Can I fabricate a return spring?
RE: Clutch Adjustment Issue: Not releasing off the pressure plate far enough
what kind of clutch do you have...and how did u adjust it when u first did it...and do you have some sort of aftermarket quadrant or something
Its a auto to manual swap. Everything is new. 10.5" Alum. flywheel, Ford pilot bearing, king cobra clutch w/ included T/O bearing, UPR quadrant & Firewall adjuster with adustable clutch cable, Reman TR3650 trans & alum. driveshaft.
I have it adjusted so that theres a 3/8" gap between t/o bearing and Pressure plate teeth. Im pretty sure the clutch is adjusted perfect. Its just that when I release it, it doesnt give me the gap that I adjusted it to. I have to manually pull back on the fork once to get the 3/8" gap.
(Basically when I let the clutch out the t/o bearing barely touches the splines, just enough to keep it spinning. once I pull the fork back to get the 3/8" gap, it stays there)
What are you adjusting besides the cable or firewall adjuster? And what kind of quadrant are you using? Make sure the correct part of the clutch cable is sitting in the end of the fork, there are two little parts at the xmsn end of the cable. The round part should be sitting in the divot of the fork, not the piece on the end. Once you get the cable in the correct place, then you shouldn't need to adjust anything on the bottom. All your adjustments should be made on the firewall adjuster. If you are using a double hook quadrant the make sure you are using the correct hook for your cable. The one closest to the firewall is for the stock clutch cable and the farther one is for an aftermarket adjustable one.
Where did you get this 3/8" specification? [/align][/align]The clutch cable should be adjusted so that there is 1-1/4 to 1-3/8" freeplay, I.e. motion before you feel the ToB start to press decidedly on the Belleville spring fingers. It's normal for the ToB to be touching the spring when you release the pedal, and spinning a bit (it's not loaded at this point so it won't hurt anything). In normal driving it will work itself back a bit more...[/align][/align]
Im not talking about pedal effort/height. Im talking about the actual clearance between the t/o bearing and the pressure plate fingers when the clutch is not depressed.
And the t/o bearing is not supposed to be spinning all the time, only when the pedal is depressed. If it was constantly spinning it will wear out very prematurely. Alot of people have done it on here.
ORIGINAL: Kmoran81
ORIGINAL: Kmoran81
MM&FF magazine says 1/2" --- http://www.musclemustangfastfords.co.../quadrant.html
And FRPP says 1/4"---
http://www.fordracingparts.com/downl...02D302E302.pdf
So I picked in the middle and went with 3/8's
And I did a google search of "mustang throw out bearing" and theres about 20 articles that say the bearing should not spin at all when the pedal is not pressed down.
If these sources are completely wrong and the bearing is always supposed to spin, it makes a hell of a lot of rattling noise after it gets warm and sounds f'n terrible. Maybe i shoulda just went with the centerforce
