Rocker Arms FELL OFF!!! Help!!
Old 05-19-2008, 09:40 PM
2000GTFOOL
2000GTFOOL's Avatar
Default Rocker Arms FELL OFF!!! Help!!
Ok so I pulled the Valve covers off today. I started on the passenger side where the ticking noise was the loudest. Low and behold I found the 2 rear rocker arms laying in the bottom of the head. Also two other arms had some slack... Can someone please chime in and tell me what would cause this, what the effects of this is are (potential damage).. And what I will need to repair it.
I really want to fix my car.. I really need some help..
2000GTFOOL is offline
Old 05-19-2008, 10:17 PM
2000GTFOOL
2000GTFOOL's Avatar
Default RE: Rocker Arms FELL OFF!!! Help!!
Anyone have the removal procedure for the lash adjusters?
Old 05-19-2008, 10:32 PM
kecclest
kecclest's Avatar
To remove the lash adjusters with the cam followers already removed, just pull them out. To put the followers back in without taking out the cam, you'll need a spring compressor.
kecclest is offline
Old 05-19-2008, 10:48 PM
2000GTFOOL
2000GTFOOL's Avatar
Pulled them out.. I can't "see" anything wrong with them... but what exactly am I looking for?
Old 05-19-2008, 10:51 PM
pete1665
pete1665's Avatar
did you have the valve covers off or were you working on those parts previously? The only thing i can think of is if the valve spring was weak, it may not be returning fast enough causing room for the rocker arm to jump off.
pete1665 is offline
Old 05-19-2008, 10:59 PM
timeformiller44
timeformiller44's Avatar
i really need to see pics of what you found to be able to help u... i dont see how it slipped away from the cam and the spring and just "fell off"
timeformiller44 is offline
Old 05-19-2008, 11:05 PM
2000GTFOOL
2000GTFOOL's Avatar
Not really sure how to answer that.. I had the valve cover off to check the ticking it the top end.... I have some sort of oil starvation in the top end i guess..
Old 05-19-2008, 11:09 PM
2000GTFOOL
2000GTFOOL's Avatar
ORIGINAL: timeformiller44
Well my camera batteries are dead.. But basically the valve/spring are intact and appear to be normal, but the rocker was completely off the valve and lash adjuster seat and laying in the bottom of the head...
Old 05-19-2008, 11:13 PM
timeformiller44
did u take ur cam off or something.. i really dont see how it came off unless it broke... i cant see it.. i just put cams on my car and that those cams and springs hold those in pretty damn well
Old 05-19-2008, 11:17 PM
2000GTFOOL
2000GTFOOL's Avatar
Nope didnt take the cam off at all... Let me see if the battery has recharged enough to take pictures.
Quick Reply: Rocker Arms FELL OFF!!! Help!!
