A1000 fuel pump on daily driver?
I think I'm going with the A1000 fuel pump but I'm a little worried about the noise. Does anyone have any experience with this? Would it be TOO loud? I don't mind a little bit but i just dont want it way too much. thanks
RE: A1000 fuel pump on daily driver?
What fuel system do you have?
If you mount it with rubber inbetween it will cut down on the noise. Most exhaust noise covers the sound. I would recommend using a AeromotiveBillet Fuel Pump Speed Controller. It will keep fuel temps down and cut down on some of the noise plus it will help the pump last longer.
The only change I would suggest is run a 10 line from the tank to a filter to the pump then to a Y block with 2 8 lines 1 going to each rail. That is almost how mine is. The A1000 has -10 in and out
Dragonus18
09-09-2015 01:21 AM
mungodrums
Suspension
09-07-2015 07:22 PM
