Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Install 2-Step Launch Control
Step by step instructions for do-it-yourself repairs
MSD 2-Step Install! w/pics
well Scott and I installed the 2-step tonight.... It rules. didn't take long to install at all and everything went pretty smooth.
here are some pics and instructions/tips on how to install it. I'll post a video of it here in a bit probably, its addicting and badass haha.
Ok well you start off hooking up all of the coils to the new harness. all you do is unplug the coils and plug them into the msd wire harness and then plug the msd connectors to the coils. after I was all done i had to reverse the 2 big pigtails to get it to work. there are two ways to hook up the coil pigtails, I used the one on the upper right hand side of the instructions. if it is hooked up wrong the led will be lit up the entire time the car is running and the 2-step won't work. if its correct the led only comes one when the pedal is depressed and it works.
I also found a good mounting spot and a ground for it.
I hooked my ground wire up to where the cable for the throttle comes through the firewall just to the left of where the clutch cable comes through. its a good ground and close to my mounting location.
next for the fun part. there is a blue wire and a white wire with a blue stripe. either one can activate the 2-step. if you are using the factory neutral safety switch you will want to hook up the BLUE msd wire to the RED neutral safety switch wire. this is the ground activation because the neutral saftey switch acts as a ground.
(the white with a blue stripe is not used in this application, just cut it off and put it up somewhere safe out of the road)
Here is a crappy pic of the setup. the msd kit comes with the nice wire splicer which is the blue thing connecting the two wires.
if u have any questions feel free to ask.
RE: MSD 2-Step Install! w/pics
do you have the stock rear end? i thought our 28 spline rear end were weak as hell and dont take high rpm clutch dops/launches.
THEN AGAIN, on you tube i see s/c and nitrous GT's running slicks and cutting 1.6 60' fts on a bone stock rear so wtf gives
ORIGINAL: avexhype
Really, Ford's 8.8" (28-spline) rear is extremely reliable, and fairly strong for most normal applications.. I realize that most of the guys on here aren't after that, so they pursue the 31-spline.. That's a fact, 31-spline are very much worth the extra money they require for the center section and axles.. It all depends on your application..
There's a reason Ford's been using it since the 60's..
JT
ORIGINAL: dimebag
so... what tells it to not work when you press the clutch btwn gears?
and about the 8.8 breaking, I am only on dr's and I do race my car a LOT, at test and tune and NMRA events. I am going to slicks soon and I am going to to a 31 spline axle conversion. but the stock axles can take quite a bit of punishment.
ORIGINAL: 01GT4.6
nice, but my SCT has it built in.... nothing to mount
Wait, so I have to splice the factory RED wire on the Neutral safety switch?
What if i decide to switch back to stock?
Also, there is only one ground wire involved in all of this installation, correct?
What if i chose to use the 12v power source (blue/white wire) instead of the ground (blue wire)to activate the2 step, will i still need touse the ground?
