Throwing codes P0171, P0174 Sys too lean 1,2 how do I fix this?
Old 08-14-2008, 11:47 PM
llamatymer
llamatymer's Avatar
Default Throwing codes P0171, P0174 Sys too lean 1,2 how do I fix this?
Hey guys, my car is throwing a couple of codes sys too lean 1, and 2. Does anyone know how to fix this or what causes it?
Thanks guys,
-Matt
llamatymer is offline
Old 08-15-2008, 12:02 AM
avexhype
avexhype's Avatar
do you have cats on ur mid pipe?
avexhype is offline
Old 08-15-2008, 12:16 AM
llamatymer
llamatymer's Avatar
No, I have mil's, and the rear o2's are shut off with the xcal2 i'm not sure if I need the mil's anymore. Also I tried putting it back to the stock tune, and it was still throwing the codes. It's weird when I first install the tune it doesn't do it, but like 20 mins later they come on.
Thanks,
-Matt
Old 08-15-2008, 07:42 AM
jwog666
jwog666's Avatar
cats or not it wont matter, those codes are for the upstream sensors. the light goes off after u install your tune because doing that erases all codes. clean your maf, if its dirty it will not read the volume of air correctly and these codes will be set. if that doesnt fix it check for vacuum leaks or any air intake leaks
jwog666 is offline
Old 08-15-2008, 10:58 AM
llamatymer
llamatymer's Avatar
Ok, I'll give that a try, and thanks for the info.
Old 08-15-2008, 08:15 PM
mustangman03
mustangman03's Avatar
It also could be your fuel filter or the fuel pump itself. Have you ever changed your fuel filter?
mustangman03 is offline
Old 08-15-2008, 08:41 PM
tbirdscwd
tbirdscwd's Avatar
I had the same codes when my fuel pump was going out. But then again, I was throwing low fuel pressure codes too.
tbirdscwd is offline
Old 08-16-2008, 08:48 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
All good suggestions,
Here's what the shop manual says about those codes...
cliffyk is offline
Old 08-16-2008, 02:55 PM
FixFalcon
FixFalcon's Avatar
Originally Posted by cliffyk
Great link, thanks!
FixFalcon is offline
Old 08-16-2008, 04:29 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Do the simple checks.... You dont hear any exhaust leaks do you? Leaky manifolds or collectors will set lean codes.. You probably have a vacuum leak.. Spray some 2+2 around the intake where it bolts to the head, and around the tb/plenum + vac lines. If you hear a difference in RPMs when u spray a certain spot, theres the leak.
WhiteFoxGT is offline
Quick Reply: Throwing codes P0171, P0174 Sys too lean 1,2 how do I fix this?
