Im stumped.
Im stumped.
alright. i have a 96 gt and the wierdest thing is happening. if i get on it at all the oil pressure goes straight down to low. but cruising its fine. also in higher gears if you get on it the rpm's go up but the car doesnt go any faster. you have to let off and then it will speed up. its almost like something is slipping? i have no clue but if anyone has suggestions i would appreciate it.
Youre way low on oil.......In a nut shell, youre low on oil. The self adjusting hydraulic lifters arent pumping up all the way so youre not getting the full valve lift that you should be getting.
Check your oil, or better yet change your oil and use a high quality filter like WIX. Put some Castrol syntec 5w50 in there and it should run fine. Check for leaks.
-P.
-P.
-P.
-P.
The low oil pressure is either a bad sender or bad pump. You can buy a cheap mech oil pressure gauge for $20 and to see the the pressure is.
As for the no power its probably your clutch.
The "lash adjusters" control just what they are called, the lash. They do not have anything to do with the lift of the valve. If this was a push rod engine with hydraulic lifters then I would agree with you but its not.
the lash adjusters will colapse if they dont have sufficent oil pressure reducing valve lift, which will cause problems. +1 on the clutch this could cause the loss of power complaint as well
Assuming he has a manual transmission the only thing that could do that would be a slipping clutch.
The oil pressure issue could be oil level related. A recent thread revealed that the change from the 5 qt to the 6 qt engine fill recommendation in 2002 was not related to a change in the oil pan capacity; but rather due to Ford's engineering team finding that 5 qts was insufficient to prevent oil starvation at higher revs.
Lash adjusters stabilize the cam followers they do not push the cam followers to make them press on the valve tip to open it. If you lose oil pressure and a lash adjuster collapses it will not effect lift but the cam follower will now bounce around which is the ticking sound you hear when it happens. You both are thinking of hydraulic "lifters". Completely different animal.
thanks for all of the ideas. the car is indeed a 5 speed. actually has a tko 500. so the clutch is definatly most likely the speed problem. as for the oil pressure i dont seem to be low on oil so im going to check out the oil pump/ oil pressure sender.
If OTH it does not fully compress during normal operation (I.e. it behaves as a hydraulic lifter, which do not fully compress under load) then its being collapsed would affect valve lift.
I have no idea as to whether it fully collapses under load or not, if it does then it's a crappy design because high speed metal-to-metal impact it never a good thing--it would also I suspect be quite noisy.
This would also not account for the "slipping" the OP reported...
CMcNam
10-30-2022 11:40 PM
