Cigarette lighter doesn't work..
Old 10-22-2008, 06:43 PM
blackstallion666
blackstallion666's Avatar
yea its just a power outlet not meant for the lighter.
blackstallion666 is offline
Old 10-22-2008, 09:16 PM
bolt.com
bolt.com's Avatar
mine works too good.........I just got a new cigarette lighter from MGW and the thing shotts halfway across the cabin when it ejects.
What the fcukk is up with that??
bolt.com is offline
Old 10-22-2008, 09:22 PM
blackstallion666
you must have the rocket lighter lol
Old 10-22-2008, 09:50 PM
Evenexchange
Evenexchange's Avatar
Are you being sarcastic I hope? hah
Evenexchange is offline
Old 03-01-2017, 08:41 PM
Lance Gillespie
Lance Gillespie's Avatar
Default Same issue hope you guys can help me
Ok i know alot about electrical systems and how they work due to that i got a degree in it. But i have the same issue in my 1998 mustang base model v6 5 speed manual. The fuse is good and it has 12v going across it. The ground wire to both auxiliary outlets are good but no power to the outlets. I am stumped the wires are fine no damage. Im thinking of spicing into the ignition wire on the radio for power but i want to try to fix the problem first. Can any of you help me?
Lance Gillespie is offline
Old 10-11-2017, 05:00 PM
Andross
Andross's Avatar
There are 3 fuses which control the cigarette lighter and accessorie port in the center console of these mustangs the cigar lighter the power seats and the convertible top fuses in the fuse box located under the hood of the car. Took me two days and a multimeter to figure it out.
Andross is offline
Old 12-21-2017, 07:32 PM
Jim74656
Jim74656's Avatar
What fuse number should I check if only the power point below the radio has failed? I’m not sure if it’s mentioned
Jim74656 is offline
baddog671
07-26-2016 01:20 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
09-17-2015 07:57 PM
wenmill
09-11-2015 07:07 AM
Quick Reply: Cigarette lighter doesn't work..
