99-04 Complete Interior Color Swap - Page 3 - MustangForums.com
Old 11-24-2008, 11:34 AM   #21
ashtondiff
ashtondiff's Avatar
dark charcoal the only way to go on a black car.
ashtondiff is offline   Reply With Quote
Old 11-24-2008, 09:29 PM   #22
Blk N Wht GT
Quote:
Originally Posted by gec View Post
Black Suede right over the existing headliner.
So where would I get black suede like that? How much would it cost? And how would I go about installing it?
Blk N Wht GT is offline   Reply With Quote
Old 04-12-2013, 09:35 PM   #23
gt_orange
this is not a direct swap. I just did a 2000 to a 2002, the kinks you run into are
1> the 2001-2004 clusters run power the defrost, causing the defrost to be on no matter if the key is off or on.
2> the dash harness pigtail on the passanger side is different. you eather have to use your old harness or "like it did" create an adaptor using the old harness and pigtails from your parts car.
3> after the swap my ac clutch doesnt work, not getting power, checked with a volt meter.
4> the mach 460 on 2001-2004 grounds under the rear seat. the 99-00 ground under the dash. meaning that you will have to cut the green and black wire under the driver kick panel and ground it.
5> not sure about traction control, my abs light is on and was before hand. once i correct the fault there i can knock out some variables
what works,
1> the new fog light switch does work without modification.
2> the double din 6 disk works well with the 460 amps that came with my car.
anyone with a solution to the items not listed above please comment. aside from that my car runs fine. the interior looks factory fresh, down to the seatbelts.
Plus the 03/04 gt's used a different a pillar trim, which sticks out more, looks aggresive
gt_orange is offline   Reply With Quote
Old 04-14-2013, 11:23 AM   #24
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I really like the tan interior. When I was shopping for the GT I knew exactly the color combination I wanted. Dark blue with the tan interior and tan top.
My neighbor hooked me up with a complete replacement tan interior out of a low mileage coupe that I'm storing in the attic. Front seats, door panels, airbags, console and steering wheel so I'm hooked up for my eventual restoration.
Black convertible interiors in Florida are brutal.
fastbackford351 is offline   Reply With Quote
Old 04-14-2013, 12:01 PM   #25
robb15033
robb15033's Avatar
I used black vinyl spray dye on some of the interior of my first Mustang along with new black carpet. NOW though, I appreciate the saddle interior because I read an article about Carrol Shelby and his development of the first GT500KR series car & choosing tan purposely. So it's a physiological thing for me, once I found out that Shelby has a preference for saddle, I now love it, respect it, and want to keep it. It was all in my head, for me anyways....
robb15033 is offline   Reply With Quote
Old 04-14-2013, 08:10 PM   #26
Sxynerd
Sxynerd's Avatar
DEAR GOD.
Sxynerd is offline   Reply With Quote
Old 06-10-2016, 08:56 PM   #27
mwalls_slowgt
I am about to do the same thing, took the black interior out of a wrecked 2003 Mach to put into my tan leather 99 GT. I am going with aftermarket steering wheel, rear seat deletes, and racing seats with a harness, and of course the aftermarket radio. Other than that, it will be all stock (or look the part) black interior. It shouldn't be that hard. Most of the cheap plastic from this generation Mustang should pop right out or snap or bolt. Nothing too complex, I hope. Will let you know the progress. I have a few more pieces missing, but I will start soon.
mwalls_slowgt is offline   Reply With Quote
Labor Day Weekend Special Granatelli Sales GT S197 General Discussion 5 03-25-2016 09:01 PM
Labor Day Weekend Special Granatelli Sales The New S550 2015-2016 Mustang 5 12-27-2015 07:28 PM
01 Mustang Overheating :( MusicCity615 General Tech 7 09-12-2015 08:05 AM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 08:30 PM
Huge Savings from Lethal Performance.com!(Whipple, McLeod, Kooks, & MUCH MORE..) Boostaddict Lethal Performance 2 09-08-2015 10:56 PM
04, 2001, 99, 9904, code, codes, color, colors, complete, diffuser, interior, mustang, rear, swap, swapping
