Go Back   MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-07-2008, 04:54 PM   #1
makriluc
Arrow Replacing a ball joint... Argggghhh
Ok, 96 Cobra. Replacing a ball joint. How the heck do you get the ball joint shaft out of the knuckle......
The car is jacked on stand under the frame, so the suspension is free of the car's weight. I've loosen the ball joint nut for half an inch. I've sprayed PB Blaster, heated the knuckle, now hamering on the friggen nut, nothing. It's not moving. I tought it would be easy as the is probably still some tension from the coil spring......
Any toughts would be appreciated
Thanks
makriluc is offline   Reply With Quote
Old 12-07-2008, 05:03 PM   #2
Tazzy
Vehicle: 2004 Ford Mustang GT
Don't hammer the nut, hammer the side of the knuckle that holds the shaft with a good sized hammer.
Tazzy is offline   Reply With Quote
Old 12-07-2008, 05:08 PM   #3
4.698GT
1998 Ford Mustang
Vehicle: 1998 Mustang GT
jack up on the control arm to put a good amount of pressure on it, then start whacking at the balljoint with a good 3 to 4 lb hammer
__________________
1998 Mustang GT- Cammed PI Motor and bolt ons 292 whp 306 Trq, tubular front suspension, Built Rear
4.698GT is online now   Reply With Quote
Old 12-07-2008, 06:04 PM   #4
vanquish
Vehicle: 2000 Mustang GT
If all else fails there is an air tool snapon (and possibly other companies) makes to get them out. You should be able to hammer it out or use a regular ball joint tool. You should have this tool if you're putting the new one in anyways right?
__________________
2000 Ford Mustang GT
Vortech V1 S Trim
JE 194329 Forged Pistons
CRS 5933F30 Forged Rods
Fel-Pro Gaskets & Bolts
Ford Racing 11" Clutch
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
vanquish is offline   Reply With Quote
Old 12-07-2008, 07:44 PM   #5
03greyGT
03greyGT's Avatar
Vehicle: 2003 Mustang GT
Send a message via AIM to 03greyGT
Yea theres a ball joint tool, sometimes called a pickle fork. Its a U shaped tool thats tapered. You wedge it inbetween the spindle and control arm and pound the heck out of it with a hammer. Thats the best way to do it IMO
__________________
03 GT, full bolt-ons, cammed, gears...
03greyGT is offline   Reply With Quote
Old 12-07-2008, 09:08 PM   #6
BlackStang31
Send a message via AIM to BlackStang31
yea the u shape on an air gun. done thats wat i use at work
__________________
BlackStang31 is offline   Reply With Quote
Old 12-07-2008, 09:24 PM   #7
vanquish
yes that would be easiest. However, if he is doing balljoints to begin with, you need the regular balljoint tool that is required to press the new balljoint in. You definately have this or else you wouldn't be taking the old joint out. I always try to hammer the old one out too but you can use the tool you should already have to get the old one out.
__________________
Vortech V1 S Trim
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
Old 12-08-2008, 02:52 AM   #8
makriluc
I need to replace the boot as it is all cracked. All I need is to is to seperate the ball joint from the knuckle. I don't need to replace the whole ball joint and I know it is pressed in the control arm. I've tried the pickle fork to no avail. I'll try to get my hand on a BJ puller. So at least I was doing it the right way.
Thanks for your comments guys.
98, ball, ford, foxbody, joint, joints, mustang, removing, replacing, seperate
Featured Sponsors
New Sponsors
Advertising Information - Contact Us - Ford Mustang Forums - Archive - Top
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
