I've just recently started having a problem with my car not wanting to allow the shifter into first gear. I sometimes have to pump the clutch to get it into gear. No problems in any other gear. Can this be solved with a simple adjustment?
if so just pull up on the pedal and it should adjust itself.
the stock adjuster blows donkey d*ck!!!!! adjustable clutch kit is the only way to go!!!! i love my steeda kit and there adjustable clutch pedal stop is worth the extra cash too!!!
I'm preety much having the same problem but only in third. I will be getting my spec adjusted on Friday, hopefully that will solve my problem. I most def agree with everyone else start with the quick fix until you have to spend alot of money. Good luck!
I've been having a similiar problem with the car sometimes wanting to grind 3rd. Adjusting the stock quadrant is a pain in the ***, and doesn't last too long. My Maximum Motorsports kit should be here monday, I can't wait.
