Old 11-20-2015, 12:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
T-3650 ~ T-56 swap with complete instructions
Old 03-11-2010, 01:03 PM
  #31
Moonshine
Moonshine's Avatar
Hrm... Something to look into in the future I guess. Pretty satisfied with my tranny as of yet. But if ever I need a new one for any reason...6 gears would be cool haha! Thanks bud!
Moonshine is offline
Old 05-09-2010, 02:19 PM
  #32
UnsuspectedPower
UnsuspectedPower's Avatar
same thing that i posted on youkairyu32's trans. swap thread. Now i have a question about my car. its not a mustang but has pretty much the same setup from the engine to the rear diff. Its a 1997 mercury grand marquis. i dont know about the ECM though if its the same or not. was planning on doing the swap in 2 years and wante to know if i could before i got all the parts. Dont know what model of transmission it is but i want to put in the t-56. The pedal cluster i am very unsure about. either pm me or reply. Thanks!
UnsuspectedPower is offline
Old 05-11-2010, 08:37 AM
  #33
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
The gear ratio is a subjective decision and will have to make a decision. I chose my #1260 due to the even "steps" between ALL the gears rather than the HUGE differential between 1st~2nd and 4th~5th. I would ask you to contact Bruce @ Moddern Driveline and ask about such a swap. I don't know if he can help you, but he will know much more than I.
As for pedal fitment and ECM changes... I have absolutely no idea.
Jazzer
Jazzer The Cat is offline
Old 07-15-2016, 01:13 PM
  #34
sotom1
sotom1's Avatar
I want to make this swap as well. Thanks for the info
sotom1 is offline
Old 02-07-2018, 12:36 AM
  #35
2vcontinued
2vcontinued's Avatar
Originally Posted by Jazzer The Cat
Had a couple road trips now and can only say the following...
AWESOME!!!
Anyone considering this swap, is well advised to do so
1st~2nd is nice and smooth now, and less likely to get a herky-jerky as the ratio is much closer. That's not all folks, just check what's behind door #2... The loss of the 4th~5th gear gap I am now able to cruise at 55 mph with no need to choose between 2600 rpm 4th or 1600 rpm 5th With the new T-56, she now runs at 2200 rpm in 5th so have some power for those all those little hills in Marin Co. I always hated having to drive a little faster than I would like JUST to retain some semblance of HP in 5th gear.
This is a spectacular upgrade and recommend it to anyone with the means to do so
Jazzer
Hey man. I'm thinking about doing this same swap into my 02 GT could u tell me wat all is needed as far as parts and modification. I know I'm going to need to change shifter, clutch, driveshaft, and crossmember but is there anything else as far as flywheel and what modification do I have to do to my clutch cable if any?
2vcontinued is offline
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: T-3650 ~ T-56 swap with complete instructions
