Old 10-12-2015, 01:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
abs light is on..how to check??
Old 01-19-2009, 09:57 AM
6sphere
6sphere's Avatar
Default abs light is on..how to check??
After I had my gears put in, there has been a pulsing in the brake pedal when I slow down. It really only happens when I get in the lower speeds like 10mph and lower. Over at StangNet someone mentioned that it could be the rear rotors.
Now my abs light is on. It never came on before I had the gears put in, now it will come on every once in a while, especially when im on the highway. It came on today when I got on the highway and another time as well. And whats weird is when the light is on, my brake pedal doesn't pulse when I slow down.
How can I check the code? Im gonna try with my xcal 2 after posting this, so we'll see if it works or not.
6sphere is offline
Old 01-19-2009, 11:02 AM
6sphere
6sphere's Avatar
Xcal didn't work...
6sphere is offline
Old 01-19-2009, 03:41 PM
dennis_112
dennis_112's Avatar
Its not a CEL its your ABS sensor, check to make sure they didnt unplug one of your ABS sensor's, or or could be loose, or it couldnt be related and your brakes need replaced.
dennis_112 is offline
Old 01-19-2009, 03:43 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
If it started after the gears, the installer probably damaged the sensor where it goes thru the axle housing. They get seized in there and take some manipulating to get out. Yank the rear wheels and inspect the senors for damage and make sure hey are seated all the way in
WhiteFoxGT is offline
Old 01-19-2009, 06:57 PM
LynnBob Mustang
LynnBob Mustang's Avatar
My ABS light came on after I got done putting my springs in on it's test drive. I put it up for the winter right after I did it and I havn't gotten time to look into what happend to make it come on because it has been too cold out. But I'm guessing I did something with one of the cables.
Lynn
LynnBob Mustang is offline
Old 01-19-2009, 08:59 PM
6sphere
6sphere's Avatar
I went to the place I took it too and told them about it. They said to drop it off sometime and they'll check it out.
6sphere is offline
Old 01-19-2009, 09:06 PM
livefast1
livefast1's Avatar
to do the gears you have to pull the axles and to push the axles in to get the c clips out you have to at least loosen the abs sensors and pull them out a little (or all the way out whatever floats your boat), they probably didn't put them all the way back in which is why your abs is activating. you could check it with a scan tool, monitor which abs sensor isn't responding.
livefast1 is offline
Old 01-19-2009, 09:26 PM
6sphere
6sphere's Avatar
I'll tell them about the abs sensors. I still dont understand why the brakes pulse. They had to take the rear ones apart to do the install so maybe they did something wrong putting them back on.?
6sphere is offline
Old 01-19-2009, 09:30 PM
Nolimits31
Nolimits31's Avatar
where did you get them from? check to see if they are warped. we sometimes have problems at our shop with napa brand and advanced auto products but they are covered under warranty.
Nolimits31 is offline
Old 01-19-2009, 09:38 PM
livefast1
livefast1's Avatar
when you say pulse does the pedal feel wierd or does it feel like the brakes are warped (feel a vibration in your seat).
if they messed up or didn't install a sensor all the way in, the abs module will see a differential in wheel speed which tells it a tire has lost traction and will cause an abs stop, which would also explain why your abs light is on.
Quick Reply: abs light is on..how to check??
